parabolic velocity boundary condition
Like Tree1Likes
  • 1 Post By nazmulislam
Old   April 28, 2023, 10:08
Default parabolic velocity boundary condition
Nazmul Islam
nazmulislam is on a distinguished road
I am trying to implement parabolic velocity boundary condition at the inlet and writing the corresponding codes in the 'u' file within '0' folder as in the attachment.
However, when I run the simulation with icoFoam, I am getting the error message as in the attachment.
I appreciate your help in this regard.
Cheers,
Nazmul
nazmulislam is offline   Reply With Quote
Old   April 29, 2023, 06:11
Tobermory will become famous soon enough
I know that the error messages can sometimes feel a little daunting to read, but do try - it literally tells you what the problem is in the first line. You are missing the "name" keyword from your boundary definition (see e.g. https://cpp.openfoam.org/v8/classFoa...d.html#details). Just add something like:
name    parabolicCodedInlet;
after the type and value keyword lines, and it should work.
Tobermory is offline   Reply With Quote
Old   April 29, 2023, 10:37
Nazmul Islam
Hi Tobermory,
Thanks for your suggestion. However, I have tried as you suggested, but got a different error message as in the attachment.
Cheers,
Nazmul
Old   May 1, 2023, 07:02
Nazmul Islam
I have solved the problem. There was a typo in the code. I was written "Patch", but it should have written "patch".
Now it works. Thanks for your suggestion.
Cheers,
Nazmul
Tobermory likes this.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Import .csv - velocity profile - error eSKa CFX 9 April 3, 2021 14:38
Complex velocity boundary condition Pavithra OpenFOAM Running, Solving & CFD 0 October 2, 2019 01:17
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
