April 14, 2023, 10:04 |
fluid properties in OpenFoam
Rep Power: 5 |
Hello everyone,
I am using interFoam and running the DTCHull tutorial. I would like to know which fluid properties are used in tutorial, such as density for the 2 fluids. Does a file contains those informations? Thank you for your help, Denis |
April 14, 2023, 10:17 |
M
Rep Power: 13 |
The properties of the fluids and other model parameters are usually located in the constant folder.
Depending on the OpenFOAM-Version you are using, this might be located in different files. In OpenFOAM 10, it will be located in constant/physicalProperties.water and .air https://github.com/OpenFOAM/OpenFOAM...CHull/constant A short search for this tutorial and you find this kind of information for ESI is located in the constant/transportProperties file. https://develop.openfoam.com/Develop...portProperties |
April 17, 2023, 04:28 |
Rep Power: 5 |
Thanks a lot!
interfoam, openfoam |
Properties as a function of space/cellzone – porous region | absorbedsponge | OpenFOAM Pre-Processing | 0 | September 29, 2021 15:59 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 07:15 |
Fluent Fluid Properties | typhoon1010 | FLUENT | 4 | July 23, 2016 07:27 |
Changing the properties of a fluid | TheForumLord | FLUENT | 2 | June 12, 2014 02:25 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
