Negative initial temperature T0 in rhoPimpleFoam
Like Tree1Likes
  • 1 Post By Fouch
Old   March 28, 2023, 10:34
Default Negative initial temperature T0 in rhoPimpleFoam
mohammad morovati
mohammad morovati is on a distinguished road
I am trying to simulate a fan inside a canal by rhoPimpleFoam solver.
Fan is rotating by w=104, and I face to negative initial temperature in 3rth part of first iteration.
It would be great appreciated if someone could guide me.
all files are attached
mohammad morovati is offline   Reply With Quote
Old   March 31, 2023, 10:42
Fouch is on a distinguished road
For compressible cases you have to limit T and U in fvOption (constant directory) :
|  \\    /   O peration     | Version:  v2106                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvOptions;
/*viscousDissipation
    type            viscousDissipation;
    enabled         true;
limitT
    type       limitTemperature;
    min        230;
    max        400;
    selectionMode all;
limitU
    type            limitVelocity;
    selectionMode   all;
    max            400;
This is an example above but you have to adapt the values to your case.
Best regards,
hogsonik likes this.
Fouch is offline   Reply With Quote
fan, rhopimplefoam
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 19:17
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
