Comparison of results calculated by OpenFOAM's turbulent model kwSST in weir flow
Like Tree2Likes
  • 1 Post By Santiago
  • 1 Post By piu58
Old   March 22, 2023, 06:13
Default Comparison of results calculated by OpenFOAM's turbulent model kwSST in weir flow
YJ-Kwon
Akun is on a distinguished road
Hello guys.
I am not good at English, so there may be some awkward parts in the question. I would appreciate it if you could understand this.
I calculated with OpenFOAM following the same weir case as the paper, but I don't know if this result is correct. The turbulence model used k-w SST.
The flow away from the weir end is different from the picture in the paper.
I think it's normal if the same flow as the attached second picture continues to come out continuously. However, the calculated flow converges after a certain period of time, just like the picture I calculated in the first picture.
The attached second picture is described as a capture of the instantaneous flow in the paper.
I want to know if the weir case I calculated is well calculated, is there a post to refer to, or I'm wondering if you guys have any opinions.
Thank you for reading my post.
Akun is offline   Reply With Quote
Old   March 22, 2023, 13:31
Santiago Lopez Castano
Santiago is on a distinguished road
You are experiencing a problem that also happens on physical experiments: lack of areation behind the jet. Make sure to leave a pressure inlet in the jump region in order to allow air to enter.
Akun likes this.
Santiago is offline   Reply With Quote
Old   March 23, 2023, 01:36
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
For me, it looks like you used a sReynolds number much lower than in the reference work. Could you give the numbers, please?
Akun likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 23, 2023, 01:56
YJ-Kwon
Thank you for your answer. I'll try as you comment
Old   March 23, 2023, 02:00
YJ-Kwon
The Reynolds number is 4845.27.
Old   March 23, 2023, 02:32
abdikerim kurbanaliev
kerim is on a distinguished road
which version of the package did you use? Is that OF6?
kerim is offline   Reply With Quote
Old   March 23, 2023, 02:39
YJ-Kwon
No, to be exact, v2206 on www.openfoam.com
k-w-sst, open channel flow, weiroverflow
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Transient thermal deviating results RichardL ANSYS 0 June 6, 2018 11:28
How to model a turbulent flow over a cylinder? Mahbub FLUENT 14 February 10, 2018 12:14
porous media turbulent model P-dL, I get the different results? is the model wrong? hitchenxue FLUENT 0 July 13, 2014 06:57
Need experimental results on turbulent flow babyface Main CFD Forum 1 May 22, 2002 13:52
