simplefoam does not stop upon convergence
Like Tree2Likes
  • 1 Post By Hr_kules
  • 1 Post By michael3000
Old   March 20, 2023, 09:31
Default simplefoam does not stop upon convergence
Schweiz
michael3000 is on a distinguished road
I set the following convergence criterion in the fvSolution dict:
SIMPLE
    residualControl
        p               0.005; // default: 1e-4
        U               0.005; // default: 1e-4
        "(k|omega|epsilon)" 0.005; // default: 1e-4
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
simplefoam "acknowledges" the criterion in the log:
SIMPLE: convergence criteria
    field p	 tolerance 0.005
    field U	 tolerance 0.005
    field "(k|omega|epsilon)"	 tolerance 0.005
On t=46 convergence is reached, but it still does not stop but runs to the 50 timesteps as given in the controlDict
Time = 46
smoothSolver:  Solving for Ux, Initial residual = 0.00132339, Final residual = 0.000118212, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.00828419, Final residual = 0.000747561, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.00586836, Final residual = 0.000477364, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.0446904, Final residual = 0.00266224, No Iterations 2
time step continuity errors : sum local = 5.56276e-05, global = -6.44437e-06, cumulative = -0.000195527
smoothSolver:  Solving for epsilon, Initial residual = 0.00314368, Final residual = 0.00022914, No Iterations 1
smoothSolver:  Solving for k, Initial residual = 0.00534749, Final residual = 0.000112692, No Iterations 2
ExecutionTime = 2.18 s  ClockTime = 4 s
controlDict:
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         50;
deltaT          1;
What do I need to change such that simplefoam actually stops upon convergence? (There are many questions about this already, but as far as I see, I do everything as recommended...)
michael3000 is offline   Reply With Quote
Old   March 21, 2023, 09:48
Nico
Hr_kules is on a distinguished road
Hi, as far as i can tell, you didn't reach convergence. The criteria applies to the inital residual.
In your case for p = 0.005
The inital residual for p = 0.0446904
For U = 0.005
The initial u residuals:
Just increase the endTime and see if the case converges
michael3000 likes this.
Hr_kules is offline   Reply With Quote
Old   March 21, 2023, 10:51
Schweiz
That explains it! Thanks a lot :-)
Hr_kules likes this.
Square duct flow with cyclic inlet outlet - simpleFoam Convergence issue Vino OpenFOAM Running, Solving & CFD 7 January 25, 2019 03:55
simpleFoam: simple 1-D channel flow, yet very strange convergence behavior kishpishar OpenFOAM Running, Solving & CFD 2 June 20, 2013 14:55
simpleFoam Convergence Stalling Greg Givogue OpenFOAM Running, Solving & CFD 6 March 9, 2011 21:23
Convergence Problems SimpleFOAM Kutti OpenFOAM 16 June 14, 2010 09:12
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
