shifted periodic boundary conditions
Like Tree1Likes
  • 1 Post By mAlletto
Old   March 16, 2023, 05:29
Default shifted periodic boundary conditions
Michael Alletto
mAlletto will become famous soon enough
Hello all,
does somebody know how to apply shifted periodic boundary conditions in OpenFOAM. Basically in periodic boundary conditions the velocity at the outflow is taken and reintroduced at the same lateral and vertical position at the inlet.
I wanted to do the same, but i want to shift the lateral position by some distance \Delta y being y the lateral coordinate. x is the streamwise coordinate and z is the wall normal coordinate. The scope is to avoid an annatural long living of the streamwise streaks caused by the periodic boundary conditions.
Basically I wanted to do the same as https://www.researchgate.net/publica...urbulent_flows
Is there a way to achieve this?
Best
Michael
mAlletto is offline   Reply With Quote
Old   March 17, 2023, 09:31
Michael Alletto
Maybe I can aswer the question by myself:
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version         2.0;
    format          ascii;
    class           dictionary;
    object          blockMeshDict;
convertToMeters 1;
vertices
    ( -2500  -1000   0)// 0
    ( 2500  -1000   0) // 1
    ( 2500    0   0) // 2
    ( -2500   0   0) // 3
    ( -2500  -1000   4000) // 4
    ( 2500  -1000   4000) // 5
    ( 2500    0   4000) // 6
    ( -2500   0   4000) // 7
    ( -2500    1000   0) // 8
    (  2500    1000   0) // 9
    ( -2500    1000   4000) // 10
    (  2500    1000   4000) // 11
blocks
    hex (0 1 2 3 4 5 6 7) (250 50 200) simpleGrading (1 1 1)
    hex (3 2 9 8 7 6 11 10) (250 50 200) simpleGrading (1 1 1)
edges
boundary
    east1
        type cyclic;
        neighbourPatch  west2;
        transform       translational;
        separationVector (-5000 1000 0);
        faces
            (2 6 5 1)
    east2
        type cyclic;
        neighbourPatch  west1;
        separationVector (-5000 -1000 0);
        faces
            (2 9 11 6)
    north
        type cyclic;
        neighbourPatch south;
        faces
            (1 5 4 0)
    south
         type cyclic;
        neighbourPatch north;
        faces
            (8 9 11 10)
    west1
        type cyclic;
        neighbourPatch  east2;
        separationVector (5000 1000 0);
        faces
            (0 4 7 3)
    west2
        type cyclic;
        neighbourPatch  east1;
        separationVector (5000 -1000 0);
        faces
            (3 8 10 7)
    lower
        type wall;
        faces
            (0 3 2 1)
            (3 2 9 8)
    upper
        type patch;
        faces
            (4 5 6 7)
            (7 6 11 10)
mergePatchPairs
YG Wei likes this.
Old   October 15, 2024, 06:48
Thumbs up shifted periodic boundary condition progress
Tim_ is on a distinguished road
Hi, did you get any further with this. For example working out how to do it for an arbitrary number of outlet/inlet slices? or an openfoam BC that works to similar effect?
Tim_ is offline   Reply With Quote
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 06:53
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
PEMFC module + multiple periodic boundary conditions vkrastev FLUENT 2 December 22, 2014 05:15
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
