chri
Rep Power: 3 ![]() |
I'm trying to simulate a bubble rising process using interFoam with a time-dependent boundary condition in the inlet, but I get the following error.
--> FOAM FATAL IO ERROR: keyword file is undefined in dictionary "/home/chir/OpenFOAM/chri-9/0.0715mm_test/0/U.boundaryField.inlets" file: /home/chir/OpenFOAM/chri-9/0.0715mm_test/0/U.boundaryField.inlets from line 50 to line 54. From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const in file db/dictionary/dictionary.C at line 570. FOAM exiting The content of 0/U are also pasted below. /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (0 0 0); } outlet { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } fixedWall { type noSlip; } frontAndBack { type empty; } inlets { type uniformFixedValue; uniformValue tableFile; tablefileCoeffs { fileName "/home/chir/OpenFOAM/chri-9/0.0715mm_test/0/velocity.txt"; } } } // ************************************************** *********************** // The content of velocity.txt are also pasted below. /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class IOobject; location "0"; object velocity.txt; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * ( (0.0000 (0 0 0)) (0.0005 (0 0 0)) (0.0010 (0 0 0)) (0.0015 (0 0 0)) (0.0020 (0 0 0)) (0.0025 (0 0 0)) (0.0030 (0 0 0)) (0.0035 (0 0 0)) (0.0040 (0 0 0)) (0.0045 (0 0 0)) (0.0050 (0 0 0)) (0.0055 (0 0 0)) (0.0060 (0 0 0)) (0.0065 (0 0 0)) (0.0070 (0 0 0)) (0.0075 (0 0 0)) (0.0080 (0 0 0)) (0.0085 (0 0 0)) (0.0090 (0 0 0)) (0.0095 (0 0 0)) (0.0100 (0 0 0)) (0.0105 (0 0 0)) (0.0110 (0 0 0)) (0.0115 (0 0 0)) (0.0120 (0 0 0)) (0.0125 (0 0 0)) (0.0130 (0 0 0)) (0.0135 (0 0 0)) (0.0140 (0 0 0)) (0.0145 (0 0 0)) (0.0150 (0 0 0)) (0.0155 (0 0 0)) (0.0160 (0 0 0)) (0.0165 (0 0 0)) (0.0170 (0 0 0)) (0.0175 (0 0 0)) (0.0180 (0 0 0)) (0.0185 (0 0 0)) (0.0190 (0 0 0)) (0.0195 (0 0 0)) (0.0200 (0 0 0)) (0.0205 (0 0 0)) (0.0210 (0 0 0)) (0.0215 (0 0 0)) (0.0220 (0 0 0)) (0.0225 (0 0 0)) (0.0230 (0 0 0)) (0.0235 (0 0 0)) (0.0240 (0 0.00156593 0)) (0.0245 (0 0.001063172 0)) (0.0250 (0 0.000846011 0)) (0.0255 (0 0.000696035 0)) (0.0260 (0 0.000588906 0)) (0.0265 (0 0.000509218 0)) (0.0270 (0 0.000416362 0)) (0.0275 (0 0.000336062 0)) (0.0280 (0 0.000233895 0)) (0.0285 (0 7.12525E-05 0)) (0.0290 (0 4.7625E-05 0)) (0.0295 (0 5.01143E-05 0)) (0.0300 (0 3.77587E-05 0)) (0.0305 (0 3.26555E-05 0)) (0.0310 (0 3.28253E-05 0)) (0.0315 (0 3.00343E-05 0)) (0.0320 (0 2.55025E-05 0)) (0.0325 (0 2.7974E-05 0)) (0.0330 (0 3.47557E-05 0)) (0.0335 (0 2.02958E-05 0)) (0.0340 (0 1.9056E-05 0)) (0.0345 (0 2.81555E-05 0)) (0.0350 (0 2.11088E-05 0)) (0.0355 (0 1.74512E-05 0)) (0.0360 (0 2.5883E-05 0)) (0.0365 (0 1.63815E-05 0)) (0.0370 (0 2.24218E-05 0)) (0.0375 (0 1.4104E-05 0)) (0.0380 (0 1.55229E-05 0)) (0.0385 (0 2.0793E-05 0)) (0.0390 (0 1.17405E-05 0)) (0.0395 (0 1.19289E-05 0)) (0.0400 (0 1.21918E-05 0)) (0.0405 (0 1.25422E-05 0)) (0.0410 (0 1.2932E-05 0)) (0.0415 (0 1.32342E-05 0)) (0.0420 (0 1.32109E-05 0)) (0.0425 (0 1.26991E-05 0)) (0.0430 (0 1.1704E-05 0)) (0.0435 (0 1.04686E-05 0)) (0.0440 (0 9.20825E-06 0)) (0.0445 (0 8.03881E-06 0)) (0.0450 (0 6.96891E-06 0)) (0.0455 (0 5.9968E-06 0)) (0.0460 (0 5.09135E-06 0)) (0.0465 (0 1.87577E-05 0)) (0.0470 (0 7.76778E-06 0)) (0.0475 (0 5.2274E-06 0)) (0.0480 (0 3.6938E-06 0)) (0.0485 (0 2.44637E-06 0)) (0.0490 (0 7.02536E-06 0)) (0.0495 (0 2.5946E-06 0)) (0.0500 (0 0 0)) ); // ************************************************** *********************** // |
Rep Power: 5 ![]() |
Hello
![]() You probably used the wrong keyword. OpenFoam expects a file keyword and your 0/U file only has tablefileCoeffs in your inlets boundary. |
#3 | |
chri
inlets { type uniformFixedValue; uniformValue tableFile; uniformValueCoeffs { file "velocity.txt"; } value (0 0 0); } my velocity.txt is : ( (0.0000 (0 0 0)) (0.0005 (0 0 0)) (0.0010 (0 0 0)) (0.0015 (0 0 0)) (0.0020 (0 0 0)) (0.0025 (0 0 0)) (0.0030 (0 0 0)) (0.0035 (0 0 0)) (0.0040 (0 0 0)) (0.0045 (0 0 0)) (0.0050 (0 0 0)) (0.0055 (0 0 0)) (0.0060 (0 0 0)) (0.0065 (0 0 0)) (0.0070 (0 0 0)) (0.0075 (0 0 0)) (0.0080 (0 0 0)) (0.0085 (0 0 0)) (0.0090 (0 0 0)) (0.0095 (0 0 0)) (0.0100 (0 0 0)) (0.0105 (0 0 0)) (0.0110 (0 0 0)) (0.0115 (0 0 0)) (0.0120 (0 0 0)) (0.0125 (0 0 0)) (0.0130 (0 0 0)) (0.0135 (0 0 0)) (0.0140 (0 0 0)) (0.0145 (0 0 0)) (0.0150 (0 0 0)) (0.0155 (0 0 0)) (0.0160 (0 0 0)) (0.0165 (0 0 0)) (0.0170 (0 0 0)) (0.0175 (0 0 0)) (0.0180 (0 0 0)) (0.0185 (0 0 0)) (0.0190 (0 0 0)) (0.0195 (0 0 0)) (0.0200 (0 0 0)) (0.0205 (0 0 0)) (0.0210 (0 0 0)) (0.0215 (0 0 0)) (0.0220 (0 0 0)) (0.0225 (0 0 0)) (0.0230 (0 0 0)) (0.0235 (0 0 0)) (0.0240 (0 0.00156593 0)) (0.0245 (0 0.001063172 0)) (0.0250 (0 0.000846011 0)) (0.0255 (0 0.000696035 0)) (0.0260 (0 0.000588906 0)) (0.0265 (0 0.000509218 0)) (0.0270 (0 0.000416362 0)) (0.0275 (0 0.000336062 0)) (0.0280 (0 0.000233895 0)) (0.0285 (0 7.12525E-05 0)) (0.0290 (0 4.7625E-05 0)) (0.0295 (0 5.01143E-05 0)) (0.0300 (0 3.77587E-05 0)) (0.0305 (0 3.26555E-05 0)) (0.0310 (0 3.28253E-05 0)) (0.0315 (0 3.00343E-05 0)) (0.0320 (0 2.55025E-05 0)) (0.0325 (0 2.7974E-05 0)) (0.0330 (0 3.47557E-05 0)) (0.0335 (0 2.02958E-05 0)) (0.0340 (0 1.9056E-05 0)) (0.0345 (0 2.81555E-05 0)) (0.0350 (0 2.11088E-05 0)) (0.0355 (0 1.74512E-05 0)) (0.0360 (0 2.5883E-05 0)) (0.0365 (0 1.63815E-05 0)) (0.0370 (0 2.24218E-05 0)) (0.0375 (0 1.4104E-05 0)) (0.0380 (0 1.55229E-05 0)) (0.0385 (0 2.0793E-05 0)) (0.0390 (0 1.17405E-05 0)) (0.0395 (0 1.19289E-05 0)) (0.0400 (0 1.21918E-05 0)) (0.0405 (0 1.25422E-05 0)) (0.0410 (0 1.2932E-05 0)) (0.0415 (0 1.32342E-05 0)) (0.0420 (0 1.32109E-05 0)) (0.0425 (0 1.26991E-05 0)) (0.0430 (0 1.1704E-05 0)) (0.0435 (0 1.04686E-05 0)) (0.0440 (0 9.20825E-06 0)) (0.0445 (0 8.03881E-06 0)) (0.0450 (0 6.96891E-06 0)) (0.0455 (0 5.9968E-06 0)) (0.0460 (0 5.09135E-06 0)) (0.0465 (0 1.87577E-05 0)) (0.0470 (0 7.76778E-06 0)) (0.0475 (0 5.2274E-06 0)) (0.0480 (0 3.6938E-06 0)) (0.0485 (0 2.44637E-06 0)) (0.0490 (0 7.02536E-06 0)) (0.0495 (0 2.5946E-06 0)) (0.0500 (0 0 0)) ); // ************************************************** *********************** // |
uniformfixedvalue |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 03:52 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
