How to use an velocity distribution as initial condition?
Like Tree1Likes
  • 1 Post By Yann
Old   February 6, 2023, 03:53
Default How to use an velocity distribution as initial condition?
JHC
HD6770 is on a distinguished road
Hello.
I'm trying to particle tracking using DPMFoam.
At this time, I would like to use the flow field distribution obtained by utilizing other programs as an initial condition.(I would like to put in the flow field of the entire, not the inlet condition)
but I don't know how to do it because I don't have enough basic skills.
I read a similar post on the forum, but I think it's a little different from what I want. (How to put an already-obtained velocity distribution as initial condition???)
Please let me know if there is anything I can refer to.
HD6770 is offline   Reply With Quote
Old   February 6, 2023, 04:24
Yann
Yann will become famous soon enoughYann will become famous soon enough
If you have the same mesh on both cases, you can simply copy the fields of the last timestep/iteration of your first simulation (U, p, etc...) in the 0 directory of your DPMFoam case.
Or you can use the mapField utility: https://doc.cfd.direct/openfoam/user...-v10/mapfields
I hope this helps,
Yann
HD6770 likes this.
Yann is offline   Reply With Quote
Help sought on axial compressor simulation jyotir OpenFOAM Running, Solving & CFD 0 November 17, 2021 11:49
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) Scabbard OpenFOAM Running, Solving & CFD 1 July 22, 2014 05:50
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
