Spikes in Time-Plot of transient Sloshing Solution
Like Tree1Likes
  • 1 Post By Leifheit
Old   January 23, 2023, 04:32
Default Spikes in Time-Plot of transient Sloshing Solution
Leifheit is on a distinguished road
Hi everyone,
I am simulating water sloshing in a tank. An experiment has been conducted - the results can be found in various publications such as https://doi.org/10.1016/j.compfluid.2007.11.007 or https://link.springer.com/article/10...804-012-1137-y. Also, others have simulated the case using different software yielding good results.
For those that do not have access to the files, here a short explanation of the case:
- water sloshing in a 2D rectangular tank
- tank dimensions are height = 0.6m, width = 1.2m
- the tank is excited by an oscillating motion in direction of tank width
- movement is sinusoidal; amplitude is 0.015m, omega is 4.4752 rad/s
- pressure is recorded at multiple points in the tank
- fill height is 0.36 m
Before I post my case setup files etc, here a short explanation of how I am trying to simulate the case for now:
- laminar case (I want to go turbulent in the long run but laminar needs to run nicely first)
- interFoam for a multiphase VOF (air, water) simulation
- domain movement by means of solid body motion function oscillatingLinearMotion
- ddt Scheme is Euler
- grad Scheme is Gauss linear
- div Schemes: please take a look at file excerpt below
- initialized velocity in x-direction according to movement
- adjustable time step to keep Co ~ 0.5
Here are excerpts from the files I perceive to be relevant; if you miss anything please tell me and I will post it
controlDict:
|  \\    /   O peration     | Version:  v2112                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      controlDict;
application     interFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         50;
deltaT          0.002;
writeControl    adjustableRunTime;
writeInterval   2;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep yes;
maxCo           0.5;
maxAlphaCo      0.5;
maxDeltaT       0.01;
functions{
    probes
        type            probes;
        libs            ("libsampling.so");
        // Name of the directory for probe data
        name            probes;
        writeControl    timeStep;
        // Fields to be probed
        fields          (p);
        // Optional: interpolation scheme to use (default is cell)
        interpolationScheme cell;
        fixedLocations  false;
        probeLocations
            (1.2 0.0 0.3)
            (1.2 0.0 0.426)
            (1.142 0.0 0.6)
fvSchemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(rhoPhi,U)   Gauss vanLeer;
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha)   Gauss interfaceCompression;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fvSolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    "alpha.water.*"
        nAlphaCorr      1;
        nAlphaSubCycles 1;
        cAlpha          1.5;
        alphaOuterCorrectors yes;
        MULESCorr       yes;
        nLimiterIter    3;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-8;
        relTol          0;
    "pcorr.*"
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-5;
        relTol          0;
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-08;
        relTol          0.01;
    p_rghFinal
        solver          PCG;
        preconditioner
            preconditioner  GAMG;
            tolerance       2e-09;
            relTol          0;
            nVcycles        2;
            smoother        DICGaussSeidel;
            nPreSweeps      2;
        tolerance       2e-09;
        relTol          0;
        maxIter         20;
    "(U).*"
        tolerance       1e-06;
        relTol          0;
        minIter         1;
PIMPLE
    momentumPredictor   yes;
    nCorrectors 3;
    nOuterCorrectors    100;
    //nNonOrthogonalCorrectors 0;
    pRefPoint (0 0 0.6);
    pRefValue 0;
    outerCorrectorResidualControl
        U
                tolerance  1e-4;
                relTol      0;
        p
                tolerance  1e-4;
                relTol      0;
        p_rgh
                tolerance  1e-4;
                relTol      0;
relaxationFactors
    fields
        p      0.3;
        pFinal   1;
    equations
        "U"     0.3;
        "(U)Final"   1;
p_rgh file:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    side1
        type            fixedFluxPressure;
    side2
    bottom
    top
    frontAndBack
        type            empty;
U file:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0.067128 0 0);
boundaryField
    side1
        type            movingWallVelocity;
        value           uniform (0.067128 0 0);
    side2
    bottom
    top
    frontAndBack
        type            empty;
alpha.water file:
FoamFile
    version     2.0;
    format      ascii;
    object      alpha.water;
dimensions      [0 0 0 0 0 0 0];
boundaryField
    side1
        type            zeroGradient;
    side2
        type            zeroGradient;
    bottom
        type            zeroGradient;
    top
        type            zeroGradient;
    frontAndBack
        type            empty;
Here is the Output from checkMesh:
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  10
     \\/     M anipulation  |
Build  : 10-e450dce21ea5
Exec   : checkMesh
Date   : Jan 23 2023
Time   : 08:34:52
Host   : CLEARED
PID    : 928
I/O    : uncollated
Case   : CLEARED
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0s
Mesh stats
    internal points:  0
    faces:            62216
    internal faces:   30712
    cells:            15488
    faces per cell:   6
    boundary patches: 5
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     15488
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    side1               88       178      ok (non-closed singly connected)
    side2               88       178      ok (non-closed singly connected)
    bottom              176      354      ok (non-closed singly connected)
    top                 176      354      ok (non-closed singly connected)
    frontAndBack        30976    31506    ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (0 -0.1 0) (1.2 0.1 0.6)
    Mesh has 2 geometric (non-empty/wedge) directions (1 0 1)
    Mesh has 2 solution (non-empty) directions (1 0 1)
    All edges aligned with or perpendicular to non-empty directions.
    Boundary openness (-2.26879e-17 1.88098e-14 -2.12423e-16) OK.
    Max cell openness = 1.465e-16 OK.
    Max aspect ratio = 1.03019 OK.
    Minimum face area = 4.62542e-05. Maximum face area = 0.0014.  Face area magnitudes OK.
    Min volume = 9.25085e-06. Max volume = 9.8e-06.  Total volume = 0.144.  Cell volumes OK.
    Mesh non-orthogonality Max: 0 average: 0
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 1.30476e-13 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
 End
The pressure plot I get for the probe at (1.2 0.0 0.3) is given as an attachment. If the spikes were not present, results would match up reasonably well with the experiment
Also, residual plots of the end of the simulation (last 1000 lines of the output file) are given in the attachement. For further clarity, here are the last couple of iterations from the output file:
Courant Number mean: 0.0873681 max: 0.491744
Interface Courant Number mean: 0.00141919 max: 0.436737
deltaT = 0.000721168
Time = 50s
PIMPLE: Iteration 1
DICPCG:  Solving for pcorr, Initial residual = 1, Final residual = 9.54101e-06, No Iterations 286
time step continuity errors : sum local = 1.63964e-12, global = 1.22774e-16, cumulative = 4.33396e-13
smoothSolver:  Solving for alpha.water, Initial residual = 0.000465417, Final residual = 1.55265e-09, No Iterations 2
Phase-1 volume fraction = 0.601877  Min(alpha.water) = 1.24552e-07  Max(alpha.water) = 1
MULES: Correcting alpha.water
Phase-1 volume fraction = 0.601877  Min(alpha.water) = 1.14085e-07  Max(alpha.water) = 1
smoothSolver:  Solving for Ux, Initial residual = 0.00088217, Final residual = 9.89521e-07, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.000999653, Final residual = 1.9488e-08, No Iterations 2
DICPCG:  Solving for p_rgh, Initial residual = 0.0457134, Final residual = 0.000413374, No Iterations 9
time step continuity errors : sum local = 2.82853e-05, global = 1.22492e-16, cumulative = 4.33519e-13
DICPCG:  Solving for p_rgh, Initial residual = 0.000763777, Final residual = 7.62554e-06, No Iterations 85
time step continuity errors : sum local = 5.5095e-07, global = 1.22566e-16, cumulative = 4.33641e-13
GAMGPCG:  Solving for p_rgh, Initial residual = 2.23129e-05, Final residual = 1.99164e-09, No Iterations 5
time step continuity errors : sum local = 1.34186e-10, global = 1.22444e-16, cumulative = 4.33764e-13
 PIMPLE: Iteration 8
smoothSolver:  Solving for alpha.water, Initial residual = 0.000411351, Final residual = 1.53598e-09, No Iterations 2
Phase-1 volume fraction = 0.601877  Min(alpha.water) = 1.24551e-07  Max(alpha.water) = 1
Phase-1 volume fraction = 0.601877  Min(alpha.water) = 1.14317e-07  Max(alpha.water) = 1
smoothSolver:  Solving for Ux, Initial residual = 7.20231e-05, Final residual = 8.15403e-08, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 7.22743e-05, Final residual = 1.58703e-07, No Iterations 1
DICPCG:  Solving for p_rgh, Initial residual = 9.49839e-05, Final residual = 9.48353e-07, No Iterations 8
time step continuity errors : sum local = 6.49024e-08, global = 1.22356e-16, cumulative = 4.3609e-13
DICPCG:  Solving for p_rgh, Initial residual = 1.46942e-06, Final residual = 1.45553e-08, No Iterations 82
time step continuity errors : sum local = 1.04097e-09, global = 1.2232e-16, cumulative = 4.36212e-13
GAMGPCG:  Solving for p_rgh, Initial residual = 4.09335e-08, Final residual = 5.66621e-10, No Iterations 2
time step continuity errors : sum local = 3.93621e-11, global = 1.22389e-16, cumulative = 4.36335e-13
PIMPLE: Converged
        Doing final iteration
PIMPLE: Iteration 9
smoothSolver:  Solving for alpha.water, Initial residual = 0.000411313, Final residual = 1.53734e-09, No Iterations 2
Phase-1 volume fraction = 0.601877  Min(alpha.water) = 1.14321e-07  Max(alpha.water) = 1
smoothSolver:  Solving for Ux, Initial residual = 0.000171374, Final residual = 7.1472e-07, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.000172324, Final residual = 3.90396e-08, No Iterations 2
DICPCG:  Solving for p_rgh, Initial residual = 0.00987837, Final residual = 9.7336e-05, No Iterations 8
time step continuity errors : sum local = 2.21655e-05, global = 1.22798e-16, cumulative = 4.36458e-13
DICPCG:  Solving for p_rgh, Initial residual = 0.000297428, Final residual = 2.74392e-06, No Iterations 80
time step continuity errors : sum local = 6.31496e-07, global = 1.22849e-16, cumulative = 4.3658e-13
GAMGPCG:  Solving for p_rgh, Initial residual = 2.4488e-05, Final residual = 2.67693e-10, No Iterations 4
time step continuity errors : sum local = 6.332e-11, global = 1.22822e-16, cumulative = 4.36703e-13
PIMPLE: Converged in 9 iterations
ExecutionTime = 34349.1 s  ClockTime = 34575 s
End
  Finalising parallel run
Finally, here is a list of things I have already tried:
- run simulation with very small fixed time step
- 2nd order time integration
- stricter tolerances for outer Iterations "outerCorrectorResidualControl" (did not converge in 100 iterations) ... should I try with 500?
- different relaxation factors
- turn off momentumPredictor
EDIT: Attached complete case for more clarity / providing missing information
Any hints on how to proceed would be highly appreciated!
Best Regards,
Leif
Last edited by Leifheit; January 23, 2023 at 05:19. Reason: Attached zip of complete case
Leifheit is offline   Reply With Quote
Old   January 24, 2023, 03:34
Hey everyone,
I made considerable progress, although there is still room for improvement
Changing the divergence schemes entries from
divSchemes
    default         none;
to
divSchemes
    default         none;
    div(phi,alpha)  Gauss interfaceCompression vanLeer 1;
resulted in a much cleaner pressure plot, see attachment. Will post updates if further improvement is made.
lourencosm likes this.
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
