Error while using cyclic boundaries and dynamicMesh |
November 29, 2022, 08:03 |
Al
Rep Power: 7 |
Hello
I get the following error when I use cyclic boundaries with dynamic mesh. Code:
Selected 2080 cells for refinement out of 100000. Cannot find point in pts1 matching point 3 coord:(0.0229922953 7.4724959725e-05 5.748073825e-05) in pts0 when using tolerance 5.776742700227062e-09 Searching started from:0 in pts1 Compared coord: (0.0229922953 1.149614765e-05 0.0001149614765) at index 0 with difference to point 8.545126064711205e-05 Compared coord: (0.0229922953 3.448844295e-05 0.0001149614765) at index 1 with difference to point 7.016418282820567e-05 --> FOAM Serious Error : From virtual bool Foam::cyclicPolyPatch::order(Foam::PstreamBuffers&, const primitivePatch&, Foam::labelList&, Foam::labelList&) const in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line Patch:wallRight : Cannot match vectors to faces on both sides of patch Perhaps your faces do not match? The obj files written contain the current match. Continuing with incorrect face ordering from now on! face 2 area does not match neighbour by 199.2015984000016% -- possible face ordering problem. patch:wallLeft my area:2.643233502263156e-06 neighbour area:5.286456431624018e-09 matching tolerance:0.0001 Mesh face:241456 fc:(0.007434964041583073 6.268107273923273e-05 0.0001149614765) Neighbour fc:(0.0229922953 5.748073824999999e-05 0.0001149614765) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with cyclic debug flag set for more information. From void Foam::cyclicPolyPatch::calcTransforms(const primitivePatch&, const pointField&, const vectorField&, const pointField&, const vectorField&) in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 215. |
November 29, 2022, 09:58 |
cyclicAMI
Rep Power: 8 |
Hi aliyah,
I have run into the same problem. Using cyclicAMI seems to work with dynamic mesh refinement, but not cyclic. It seems the cyclic 1-1 coupling is not possible with dynamic mesh refinement (yet). I think the foundation version has a new cyclic boundary condition that might work with dynamic mesh refinement. br. torjo |
November 29, 2022, 10:13 |
Al
Rep Power: 7 |
Hi torjo
yes, when I change it to the cyclicAMI it is working. Thanks Best, |
cyclic and cyclicGgi in foam-extend-3.0 | allenfieldin | OpenFOAM Programming & Development | 5 | November 8, 2014 06:28 |
dynamicMesh, dynamicFvMesh and meshPhi | mturcios777 | OpenFOAM Programming & Development | 0 | May 28, 2012 21:01 |
