fvMeshSticher
Like Tree1Likes
  • 1 Post By fluxCatcher
Old   October 7, 2022, 06:34
Default fvMeshSticher
Sun
PhD_Sun is on a distinguished road
FOAM FATAL ERROR:
fvMeshStitcher for changing mesh not found
Valid fvMeshStitchers are :
1(stationary)
From function static Foam::autoPtr<Foam::fvMeshStitcher> Foam::fvMeshStitcher::New(Foam::fvMesh&, bool)
in file fvMesh/fvMeshStitchers/fvMeshStitcher/fvMeshStitcherNew.C at line 86.
Hi Everyone, I need help on this? why am i getting this error on interfoam?
PhD_Sun is offline   Reply With Quote
Old   October 9, 2022, 12:59
Prakriteesh Sarma
fluxCatcher is on a distinguished road
Hello PhD_Sun
I faced the same error in one of my turbomachinery cases when I used the the new non-conformal coupling feature in OF 10. For my case, the problem was in dynamicMeshDict. The new non-conformal coupling uses an additional library in dynamicMeshDict named libfvMeshMovers.so which was not present in my dynamicMeshDict . Notice the difference between two versions of dynamicMeshDict (OF9 and OF10) in the propeller tutorial:
https://github.com/OpenFOAM/OpenFOAM...ynamicMeshDict
Maybe you have a similar issue in your case setup?
bigphil likes this.
fluxCatcher is offline   Reply With Quote
Old   November 24, 2022, 14:48
npb
npb is on a distinguished road
Hi!
I have this library (libfvMeshMovers.so) included in my dynamicMeshDict file, but I still have the same error. Do you have any idea what else could be the reason for this? May be I should include some additional file like fv..something?
Thanks!
Best regards!
npb is offline   Reply With Quote
Old   April 6, 2023, 07:50
Kevin
KevinC is on a distinguished road
Did you solve this issue?
KevinC is offline   Reply With Quote
