tableFile usage for flowRateInletVelocity
Like Tree2Likes
  • 2 Post By Dr T
Old   October 5, 2022, 13:08
Default tableFile usage for flowRateInletVelocity
T
Dr T is on a distinguished road
I am trying to use flow rates from an external file however OF keeps complaining about "values" keyword missing. The template according the documentation is
 <entryName> tableFile;
   <entryName>Coeffs
      dimensions          [0 0 1 0 0]; // optional dimensions
     fileName            dataFile;    // name of data file
     outOfBounds         clamp;       // optional out-of-bounds handling
     interpolationScheme linear;      // optional interpolation method
My usage:
 inlet
        type                flowRateInletVelocity;
        volumetricFlowRate  tableFile;
        Coeffs
            // dimensions          [0 0 1 0 0]; // optional dimensions
The dataFile above contains time and flow rates in the following format
(0.0    0.005)
(0.5   0.02)
When I run with the above setup I get the "values" entry missing error.
keyword values is undefined in dictionary "foam/tableFile_test/0/U/boundaryField/inlet/volumetricFlowRateCoeffs"
However, I was able to run by using "table" instead of a "tableFile" which is of course quite ugly/inconvenient when pasting thousands of lines in the U bc file. I was also able to run with values pasted within U file with the tableFile entry but just not able to read the values from an external file. Also, renaming the "Coeffs" to "values" directly looks for integers within braces and still doesnt look for an external file. Looks like a possible bug. Appreciate any thoughts.
Dr T is offline   Reply With Quote
Old   October 5, 2022, 13:44
T
ok, looks like I found the solution, and here is the modified version that works:
    inlet
            file            "$FOAM_CASE/0/inflow";    // name of data file
           // fileName            "$FOAM_CASE/0/inflow";    // name of data file
Not sure if this is a bug, but the TableFileReader.C is looking for a "file" entry whereas the docs mention it as "fileName". This is also crazy because the openfoam.org (V2112) requires a "file" entry and is exactly the same as above. Whereas openfoam.com(10) requires "fileName" but works with "file"!
caduqued and Michael@UW like this.
flowrateinletvelocity, openfoam 10, tablefile
Large memory usage for steady simulation Wenqiang SU2 2 May 15, 2020 14:40
How to use 2 tableFile? IgnacioSarmientoINH OpenFOAM Pre-Processing 1 August 23, 2018 08:23
New workstation for different usage scenarios - CPU and RAM natem Hardware 6 August 7, 2013 03:47
Boosting CPU usage earlybird FLUENT 2 November 2, 2012 11:32
OpenFOAM Solver/BC usage description murrayjc OpenFOAM 3 August 25, 2009 05:48
