September 10, 2022, 14:06 |
Unexpected blow up of epsilon in LRR model
Rep Power: 11 |
My computational domain is an annular axisymmetric cylinder with an angled jet like inlet and an open outlet. I've used wedge type boundary with an angle of one degree. Please find attached below the mesh.
The domain represents a bluff-body burner. The flow, a mixture of ethylene and air, enters the domain at about 20 degrees about the axis. I am running the simulation with reactingFoam with combustion turned off, to validate the cold flow before moving on to hot flow. Initially, I used the k-epsilon model for the cold and the hot flow. The simulation ran fine but the results weren't satisfactory as the model doesn't capture vortex shedding. Thus I switched to Reynold Stress Model LRR. I've since been experiencing quite an unusual issue. The simulation runs well for the base case. To perform the grid independent study, I refined the grid 1.3x-2x and right when the flow looks like it is about to reach steady state, out of nowhere the epsilon values blow up at a wall below inlet (named bluffBody). After searching through the OpenFOAM forum, I've done the following to resolve this issue:
I've attached below the case directories for both the base case and the 1.3x refined case. Please help me to resolve these issues. |
September 19, 2022, 03:28 |
Lower relaxation factors?
See also: simpleFoam tutorial PitzDaily using Reynolds stress tensor (LRR RASModel) |
September 19, 2022, 09:57 |
Found the fix
Rep Power: 11 |
The issue was with Courant number. I’m having to set maxCo to about 0.4~0.5 for bounded solution.
Incidentally, this also fixed problems I was having with decomposePar. |
lrr, ras compressible |
simpleFoam tutorial PitzDaily using Reynolds stress tensor (LRR RASModel) | dlahaye | OpenFOAM Running, Solving & CFD | 24 | August 4, 2023 14:29 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
Blow of compressible solver while using K-epsilon model in openfoam | Amit Mathur | OpenFOAM | 16 | October 6, 2013 11:09 |
k epsilon model | BrknSwrd | Main CFD Forum | 0 | July 18, 2013 02:20 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
