Number of Subdomains not equals in number of processors
Like Tree2Likes
  • 1 Post By Yann
  • 1 Post By TinusNl
Old   September 6, 2022, 03:59
Default Number of Subdomains not equals in number of processors
TinusNl is on a distinguished road
I was wondering what i did wrong. Somewhere in the forum i read that number of subdomains must be equal to number of cores to be used. Even that i have a 4 core processor i would like to reserve 1 core for fast testing before starting a real simulation.
However the script below still gives me 4 processors.
numberOfSubdomains 2;
method simple;
coeffs
n (1 1 1);
Any suggestions? Also changing the n to (1 0 0 ) not changes anything.
TinusNl is offline   Reply With Quote
Old   September 6, 2022, 04:31
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hi TinusNI,
It seems you are a bit confused about decomposeParDict, I suggest you to read the proper section of the user guide: https://www.openfoam.com/documentati...ns-in-parallel
In your decomposeParDict you are requesting 2 subdomains (ie 2 cores) but the coefficients you defined correspond to only 1 subdomain: (1 1 1) means your domain is cut by 1 in each direction => 1x1x1=1 subdomain. Another example to make it clearer: (3 2 1) will gives you 3x2x1=6 subdomains.
If you intend to run on 3 cores, your decomposeParDict should be something like this:
numberOfSubdomains 3;
method simple;
coeffs
	n (3 1 1);
Of course you also need to start the solver with the proper command, usually:
mpirun -np 3 yourSolver -parallel
Cheers,
Yann
TinusNl likes this.
Yann is offline   Reply With Quote
Old   September 6, 2022, 04:52
Thanks.
That was what i was looking for a small example.
I see that i also need to have a closer look on the other options to see if there is a way to speed up my calculations efficient as i not have that many cores available.
Yann likes this.
Boundary condition problem (Freestream) KAYANO OpenFOAM Running, Solving & CFD 5 June 1, 2021 06:57
Different flow structures obtained due to the number of processors and time-steps turbu OpenFOAM 0 January 9, 2021 23:05
[mesh manipulation] mergeMeshes for more than two fluid domains Vishsel OpenFOAM Meshing & Mesh Conversion 17 May 20, 2019 08:05
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
