gabriel rodrigues
Rep Power: 4 ![]() |
Hello !
I'm looking for some information concerning the FvSchemes, where we define the numerical schemes used in the simulation. In my case i'm running the simpleFoam for a mesh of 145.859 tetrahedrical elements and the quality is acceptable. It would be very helpful for me some tips or even a guide around it's numerical schemes. To simplify, i'd would like to know, ordering from the lesser to the most accurate numerical scheme used in simpleFoam and thus improve my results. Thank you! I'm currently using these on mine: Code:
FoamFile { format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; div(phi,age) bounded Gauss upwind; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } |
Rep Power: 8 ![]() |
Take a look at the first part of module 6: https://figshare.com/articles/media/...ining/16783657
fvschemes, numerical method, numerical scheme, openfoam 10 |
Starting from 1st order accuracy and continue to 2nd order accuracy | elochana | FLUENT | 1 | June 20, 2021 18:22 |
Fundamental questions about numerical schemes | Obad | OpenFOAM Running, Solving & CFD | 1 | May 10, 2021 10:40 |
Order of Accuracy of BC's in Open FOAM | D.B | OpenFOAM Running, Solving & CFD | 5 | April 16, 2016 21:29 |
no solution in second order schemes | immortality | OpenFOAM Running, Solving & CFD | 14 | May 23, 2013 01:39 |
Standard for checking and testing numerical schemes? | X. Ye | Main CFD Forum | 7 | August 31, 1999 17:05 |
