rhoSimpleFoam: Does it work with SRF problems? |
July 28, 2022, 06:24 |
Zeinab Abosedaira
Rep Power: 4 |
Hello all,
I hope you're having a nice time. I was asking about SRF compressible solver. So I know rhoSimpleFoam is a compressible solver, but does it work with SRF? I have a question too about how to know whether the solver works with SRF or MRF? Thank you! |
July 28, 2022, 06:47 |
Yann
Rep Power: 29 |
Hi Zeinab,
You can use MRF with rhoSimpleFoam. Have a look at the mixerVessel2D tutorial for example (tutorials/compressible/rhoPimpleFoam/RAS/mixerVessel2D). It uses rhoPimpleFoam but it should not make a difference for the MRF setup. About SRF however, AFAIK the only existing solvers are SRFSimpleFoam and SRFPimpleFoam, I don't think there is compressible solvers using SRF, at least in the two main OpenFOAM branches (openfoam.com and openfoam.org) Regards, Yann |
July 28, 2022, 06:55 |
Zeinab Abosedaira
Rep Power: 4 |
Okaay great. Thank you so much!
Hotmail and Gmail Problems - Solutions Found | pete | Site News & Announcements | 7 | November 14, 2014 11:34 |
calculating work in sixDoFRigidBodyMotion | ashkan | OpenFOAM Programming & Development | 0 | July 15, 2014 00:04 |
RP_Set_Integer does not work in parallel | 86lolo | Fluent UDF and Scheme Programming | 2 | July 3, 2014 12:37 |
Do all CFD analysts have to do some hands-on work except PhDs? | e13drd | Main CFD Forum | 2 | March 17, 2014 15:56 |
rhoSimpleFoam fvSchemes fvSolution and convergence problems | inf.vish | OpenFOAM Running, Solving & CFD | 0 | October 25, 2013 00:50 |
