Hydrofoil in Openfoam
Like Tree5Likes
  • 1 Post By Fouch
  • 1 Post By geth03
  • 1 Post By kandelabr
  • 1 Post By Fouch
  • 1 Post By Fouch
Old   July 16, 2022, 15:02
Default Hydrofoil in Openfoam
Silver Blaze
silver.blaze is on a distinguished road
Dear Altruist,
I am quite new in OpenFOAM. I am doing turbulence flow pattern of NACA0012 hydrofoil. I have done it in Ansys Fluent. Now I am tring to solve it in OpenFOAM.com to validate the answer. I wanto share the procedures:
1. I have save the ansys fluent mesh in ASCII and used a command fluentMeshtoFoam and covert the mesh file.
2. I have updated the boundary file, p and U file. ( My Re = 2.98X10^6, nu = 0.001002991, rho = 997 kg/m^3, Speed = 3 m/s)
3. Now, simpleFoam command used and execute the case with this error (functionObjects::div contErr writing field: div(phi)). Then foam file generated.
4. Open the foam file in paraview. Extraxt Cp for lower and upper surface. Plot the Cp vs x/c. but didnot get the same result like Ansys, the difference is huge.
Now my questions are:
1. Whats wrong I have done?
2. should I update other files according my Re, V, nu value?
3. How can I solve this?
Kindly help me
My files :
P:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            freestreamPressure;
        freestreamValue $internalField;
    outlet
    hydrofoil-wall
        type            zeroGradient;
    frontAndBack
        type            empty;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (3 0 0);
boundaryField
    inlet
        type            freestreamVelocity;
    outlet
    hydrofoil-wall
        type            fixedValue;
		value			uniform (0 0 0);
    frontAndBack
        type            empty;
Transport Properties
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      transportProperties;
transportModel  Newtonian;
rho             997;
nu              0.001002991;
nut:
FoamFile
    version     2.0;
    format      ascii;
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0.14;
boundaryField
    inlet
        type            freestream;
        freestreamValue uniform 0.14;
    outlet
        type            freestream;
    hydrofoil-wall
        type            nutUSpaldingWallFunction;
        value           uniform 0;
    frontAndBack
        type            empty;
nuTilda
FoamFile
    version     2.0;
    format      ascii;
    object      nuTilda;
boundaryField
    inlet
        type            freestream;
    outlet
        type            freestream;
    hydrofoil-wall
        type            fixedValue;
        value           uniform 0;
    frontAndBack
        type            empty;
silver.blaze is offline   Reply With Quote
Old   July 17, 2022, 13:04
Fouch is on a distinguished road
Could you upload the whole case ?
BR
silver.blaze likes this.
Fouch is offline   Reply With Quote
Old   July 21, 2022, 17:29
Silver Blaze
Originally Posted by Fouch View Post
BR
Sorry for my late reply. Can I send it to you in the inbox?
Old   July 21, 2022, 18:13
geth03 is on a distinguished road
Can you provide more information?
1. Checkmesh result
2. Residuals
3. FvSchemes file
4. Fvsolution file
geth03 is offline   Reply With Quote
Old   July 21, 2022, 19:33
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
looks your 'nu' is the dynamic viscosity but simpleFoam takes kinematic viscosity and doesn't need density...
www.damogranlabs.com
kandelabr is offline   Reply With Quote
Old   July 22, 2022, 01:56
Silver Blaze
1. Checkmesh result
2. Residuals
3. FvSchemes file
4. Fvsolution file
Thanks for your response. Here is the result.
1. checkMesh Result:
Mesh stats
    internal points:  0
    faces:            120350
    internal faces:   59650
    cells:            30000
    faces per cell:   6
    boundary patches: 4
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     30000
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    hydrofoil-wall      200      400      ok (non-closed singly connected)
    inlet               300      602      ok (non-closed singly connected)
    outlet              200      402      ok (non-closed singly connected)
    frontAndBackPlanes  60000    60700    ok (non-closed singly connected)
Checking faceZone topology for multiply connected surfaces...
    No faceZones found.
Checking basic cellZone addressing...
    No cellZones found.
Checking geometry...
    Overall domain bounding box (-4.851962 -5 -0.1790477) (10 5 0.1790477)
    Mesh has 2 geometric (non-empty/wedge) directions (1 1 0)
    Mesh has 2 solution (non-empty) directions (1 1 0)
    All edges aligned with or perpendicular to non-empty directions.
    Boundary openness (-4.998397e-18 -7.594004e-19 8.795399e-19) OK.
    Max cell openness = 2.390399e-16 OK.
    Max aspect ratio = 178.1052 OK.
    Minimum face area = 9.417987e-06. Maximum face area = 0.2519532.  Face area magnitudes OK.
    Min volume = 3.372538e-06. Max volume = 0.04976618.  Total volume = 49.31023.  Cell volumes OK.
    Mesh non-orthogonality Max: 42.75253 average: 6.294525
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.8074126 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
2. Residuals:
I am sorry, I am not sure, where it is.
3. fvSchemes File:
|  \\    /   O peration     | Version:  v1812                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
	version	2.0;
	class	dictionary;
	format	ascii;
	location	"system";
	object	fvSchemes;
ddtSchemes
	default	steadyState;
gradSchemes
	default	Gauss linear;
divSchemes
	default	            bounded Gauss upwind;
	div(phi,U)	        bounded Gauss upwind;
	div(phi,k)	        bounded Gauss upwind;
	//div(phi,epsilon)	bounded Gauss upwind;
    div(phi,omega)	bounded Gauss upwind;
	div(phi,R)          bounded Gauss upwind;
	div(R)	    		Gauss linear;
	div(phi,nuTilda)   	bounded Gauss upwind;
	div((nuEff*dev2(T(grad(U)))))	Gauss linear;
laplacianSchemes
	default	Gauss linear corrected;
interpolationSchemes
	default	linear;
snGradSchemes
	default	corrected;
fluxRequired
	default	no;
	p	;
wallDist
	method	meshWave;
	nRequired	true;
4. fvSolution File:
FoamFile
	version	2.0;
	class	dictionary;
	format	ascii;
	location	"system";
	object	fvSolution;
solvers
	U
		solver	PBiCGStab;
		tolerance	1E-8;
		relTol	0.1;
		preconditioner	DILU;
		maxIter	100;
	p
		solver	GAMG;
		smoother	GaussSeidel;
		tolerance	1E-8;
		relTol	0.1;
		cacheAgglomeration	true;
		nFinestSweeps	2;
		maxIter	100;
		nPreSweeps	0;
		nPostSweeps	1;
		agglomerator	faceAreaPair;
		nCellsInCoarsestLevel	10;
		mergeLevels	1;
	"(k|epsilon|nuTilda)"
		relTol	0.1;
		tolerance	1E-8;
		maxIter	100;
		solver	PBiCGStab;
	Phi
		solver	GAMG;
		tolerance	1E-10;
		relTol	01;
		nPreSweeps	0;
		nPostSweeps	1;
		nFinestSweeps	1;
		mergeLevels	2;
		maxIter	100;
SIMPLE
	nNonOrthogonalCorrectors	1;
	consistent	true;
	pRefCell	0;
	pRefValue	0;
	residualControl
		p	1E-6;
		epsilon	1E-6;
		k	1E-6;
		U	1E-6;
relaxationFactors
	p	0.75;
	epsilon	0.5;
	k	0.5;
	U	0.75;
potentialFlow
	nNonOrthogonalCorrectors	10;
	PhiRefCell	0;
	PhiRefValue	0;
Old   July 22, 2022, 01:58
Silver Blaze
Thanks, I have updated it already, but there is no major change
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
//rho             998.2002;
nu              1e-6;
Kindly help me.
Old   July 22, 2022, 04:22
If you use simplefoam you should track the residual behaviour. Look in the tutorials for simplefoam, you should find the files in one. You can also search in google how to do that, there is at least one video.
Gauss upwind is only first order accurate, so if your first run converges with upwind you can use this as starting point for second order schemes like gauss linearUpwindV grad(U) for div(phi,U) for example.
May i ask which turbulence model you use? If k-epsilon you did not upload the boundary files.
SimpleC algorithm: use 0.9 or 0.95 for all equation URF and optionally 0.9 for the fields.
Old   July 22, 2022, 04:29
Silver Blaze
Thanks for your quick response.
Yes, I am using k-epsilon.
Boundary file:
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
4
    hydrofoil-wall
        type            wall;
        inGroups        1(wall);
        nFaces          200;
        startFace       59650;
    inlet
        type            patch;
        nFaces          300;
        startFace       59850;
    outlet
        type            patch;
        nFaces          200;
        startFace       60150;
    frontAndBackPlanes
        type            empty;
        inGroups        1(empty);
        nFaces          60000;
        startFace       60350;
Old   July 22, 2022, 04:30
Silver Blaze
I can send you my case file.
Old   July 22, 2022, 04:35
Boundary file:
FoamFile
    version     2.0;
    format      ascii;
    object      boundary;
4
    hydrofoil-wall
        type            wall;
        inGroups        1(wall);
        nFaces          200;
        startFace       59650;
    inlet
        type            patch;
        nFaces          300;
        startFace       59850;
    outlet
        type            patch;
        nFaces          200;
        startFace       60150;
    frontAndBackPlanes
        type            empty;
        inGroups        1(empty);
        nFaces          60000;
        startFace       60350;
Sorry, i meant the boundary conditions for k and epsilon.
Old   July 22, 2022, 04:40
Silver Blaze
Sorry,
here it is:
k
FoamFile
	version             2.0;
	format              ascii;
	location            "0";
	object              k;
internalField	uniform 0.03375;
boundaryField
	hydrofoil-wall
		type	kqRWallFunction;
		value	$internalField;
	inlet
		type	turbulentIntensityKineticEnergyInlet;
		intensity	0.03;
	outlet
		type    zeroGradient;
		//type	inletOutlet;
		//inletValue	uniform 1.0;
Epsilon
FoamFile
	version             2.0;
	format              ascii;
	location            "0";
	object              epsilon;
dimensions	[0 2 -3 0 0 0 0];
internalField	uniform 0.000102
boundaryField
	hydrofoil-wall
		type	epsilonWallFunction;
	inlet
		type	turbulentMixingLengthDissipationRateInlet;
		mixingLength	0.3;
	outlet
		type	zeroGradient;
Old   July 22, 2022, 14:46
kandelabr's Avatar
Nejc
Just out of curiosity, you can try using fvSchemes as recommended by wolfDynamics tutorials/courses (change omega to epsilon):
gradSchemes
    default cellLimited leastSquares 1.0;
    grad(U) cellLimited leastSquares 1.0;
divSchemes
    default         none;
    div(phi,U) bounded Gauss linearUpwindV grad(U);
laplacianSchemes
    default         Gauss linear limited 0.5;
    default         linear;
snGradSchemes
    default         limited 0.5;
wallDist
    method meshWave;
But my guess is that there's something wrong with your ParaView business.
If you need lift and drag, you can use the forceCoeffs functionObject but if you insist on using PV, please share that pipeline as I had similar enterprise there in the past and was stabbed in the back multiple times. I'm lucky I survived at all
Old   July 22, 2022, 15:15
Silver Blaze
gradSchemes
divSchemes
    default         none;
laplacianSchemes
    default         linear;
snGradSchemes
wallDist
    method meshWave;
Thanks for your valuable reply. I can send you the case file.
Old   July 22, 2022, 18:01
I ran your case with the following configuration file :
fvSchemes :
FoamFile
    version    2.0;
    class    dictionary;
    format    ascii;
    location    "system";
    object    fvSchemes;
ddtSchemes
gradSchemes
divSchemes
//    div(phi,U)            bounded Gauss upwind;
    div(phi,U)            bounded Gauss linearUpwind grad(U);
laplacianSchemes
    default    linear;
snGradSchemes
    default    corrected;
fluxRequired
    default    no;
    p    ;
wallDist
    method    meshWave;
    nRequired    true;
fvSolution :
FoamFile
    version    2.0;
    class    dictionary;
    format    ascii;
    location    "system";
    object    fvSolution;
solvers
    U
        solver    PBiCGStab;
        tolerance    1E-8;
        relTol    0.1;
        maxIter    100;
        minIter    2;
    p
        solver    GAMG;
        tolerance    1E-8;
        relTol    0.1;
        nFinestSweeps    2;
        maxIter    100;
        nPreSweeps    0;
        nPostSweeps    1;
        mergeLevels    1;
    //"(k|omega|nuTilda)"
        relTol    0.1;
        tolerance    1E-8;
        maxIter    100;
        solver    PBiCGStab;
    Phi
        solver    GAMG;
        tolerance    1E-10;
        relTol    01;
        nPreSweeps    0;
        nPostSweeps    1;
        nFinestSweeps    1;
        mergeLevels    2;
        maxIter    100;
SIMPLE
    consistent    true;
    pRefCell    0;
    pRefValue    0;
    residualControl
        p    1E-6;
        epsilon    1E-6;
        k    1E-6;
        U    1E-6;
relaxationFactors
//    p    0.75;
    epsilon    0.5;
    k    0.5;
    U    0.75;
potentialFlow
    PhiRefCell    0;
    PhiRefValue    0;
I did not compared the result with yours but I used a 2nd order schemes that should be more accurate.
Test it and tell me if the result is better.
Cheers.
Old   July 27, 2022, 03:05
Silver Blaze
fvSchemes :
FoamFile
    version    2.0;
    class    dictionary;
    format    ascii;
    location    "system";
    object    fvSchemes;
ddtSchemes
gradSchemes
divSchemes
laplacianSchemes
    default    linear;
snGradSchemes
    default    corrected;
fluxRequired
    default    no;
    p    ;
wallDist
    method    meshWave;
    nRequired    true;
fvSolution :
FoamFile
    version    2.0;
    class    dictionary;
    format    ascii;
    location    "system";
    object    fvSolution;
solvers
    U
        solver    PBiCGStab;
        tolerance    1E-8;
        relTol    0.1;
        maxIter    100;
        minIter    2;
    p
        solver    GAMG;
        tolerance    1E-8;
        relTol    0.1;
        nFinestSweeps    2;
        maxIter    100;
        nPreSweeps    0;
        nPostSweeps    1;
        mergeLevels    1;
        relTol    0.1;
        tolerance    1E-8;
        maxIter    100;
        solver    PBiCGStab;
    Phi
        solver    GAMG;
        tolerance    1E-10;
        relTol    01;
        nPreSweeps    0;
        nPostSweeps    1;
        nFinestSweeps    1;
        mergeLevels    2;
        maxIter    100;
SIMPLE
    consistent    true;
    pRefCell    0;
    pRefValue    0;
    residualControl
        p    1E-6;
        epsilon    1E-6;
        k    1E-6;
        U    1E-6;
relaxationFactors
//    p    0.75;
    epsilon    0.5;
    k    0.5;
    U    0.75;
potentialFlow
    PhiRefCell    0;
    PhiRefValue    0;
Cheers.
Sorry!
Could you please send me the case file?
Old   July 27, 2022, 16:06
Could you explain what's wrong ?
Download link for the case : https://nextcloud.cm-en-transition.fr/s/kjnYJkF2RrHWbKR
Old   July 27, 2022, 18:16
Silver Blaze
Cp vs X/c graph's trend or pattern is okay, but the main problem is value. the value is not correct of Cp.
Kindly help me
openfoam, openfoam.com, paraview
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 6, 2018 00:48
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 08:18
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
