Khaled Ahmad
Rep Power: 10 ![]() |
I am just new to OpenFOAM and moving my way around. So I am working on a 3D flow in a duct, 3D backward facing step. I am exporting a mesh the boundary conditions from Pointwise.
Regarding the definition of the boundary conditions, It is OK to define all the walls (Both sides, bottom, upper and the step) in one boundary condition. If not, for the bottom walls (as they are not at the same plane), also do I need to define them separately or just under one BC? Thank you. |
abdikerim kurbanaliev
Rep Power: 16 ![]() |
See icoFoam cavity tutorial.
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 11:14 |
