foam-extend-4.1: VoF with immersedBoundaries
Like Tree1Likes
  • 1 Post By skaal
Old   July 13, 2022, 05:48
Default foam-extend-4.1: VoF with immersedBoundaries
Martin
skaal is on a distinguished road
Hi all,
I want to simulate the motion of a water-air interface in particle packings where the particles should also be able to move.
So ideally, I would use a Volume-of-Fluid solver and an IB-Method to model the particles. I was looking around for existing implementations and found that foam-extend has a very promising approach. See for example this presentation by H. Jasak.
So, I compiled foam-extend-4.1, got the immersedBoundary tutorials to run, but I fail in setting up a VoF case using these immersed boundaries.
I added an obstacle to the damBreak case to simulate something like the case shown on slide 13 (see link above) but this just fails with the message:
--> FOAM FATAL ERROR:
 Not implemented
    From function immersedBoundary::gradientInternalCoeffs()
    in file lnIncude/fvPatchField.H at line 473.
FOAM aborting
Should this kind of setup be working in this version? Am I just missing something during the setup? Or does this work only in some internal / development version which I am not aware of? For instance, I do not find any mention of the solver (navalIbFoam) indicated on that slide.
A note for clarification: In contrast to version 4.1, foam-extend-4.0 contains examples for VoF_IB setups like the damBreak with obstacle and a dedicated solver (interIbFoam) for this kind of problems. However, the underlying IBM seems have been improved since then.
Filippo_azz likes this.
skaal is offline   Reply With Quote
Old   August 30, 2022, 05:09
Martin
bump? (form requires >=10 chars)
Old   October 18, 2022, 04:12
Martin
another bump?
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 08:53
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
