July 5, 2022, 00:34 |
FOAM FATAL ERROR: cannot find file
Rep Power: 4 |
Hello.
First, here is my error message. Code:
sanghoko@ksh:~/OpenFOAM_files/pipeflow_snappyHexMesh$ ls 0 0.orig Allclean Allrun README.md constant icoFoam.log icoFoam2.log system sanghoko@ksh:~/OpenFOAM_files/pipeflow_snappyHexMesh$ cd system/ sanghoko@ksh:~/OpenFOAM_files/pipeflow_snappyHexMesh/system$ ls blockMeshDict controlDict createPatchDict fvSchemes fvSolution meshQualityDict snappyHexMeshDict topoSetDict sanghoko@ksh:~/OpenFOAM_files/pipeflow_snappyHexMesh/system$ snappyHexMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _7bdb509494-20201222 OPENFOAM=2012 Arch : "LSB;label=32;scalar=64" Exec : snappyHexMesh Date : Jul 05 2022 Time : 11:06:58 Host : ksh PID : 788 I/O : uncollated Case : /home/sanghoko/OpenFOAM_files/pipeflow_snappyHexMesh/system nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL ERROR: (openfoam-2012) cannot find file "/home/sanghoko/OpenFOAM_files/pipeflow_snappyHexMesh/system/system/controlDict" From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 547. FOAM exiting I got this error. I guess because OpenFOAM is trying to find controlDict file from here Code:
"/home/sanghoko/OpenFOAM_files/pipeflow_snappyHexMesh/system/system/controlDict" Code:
/home/sanghoko/OpenFOAM_files/pipeflow_snappyHexMesh/system/controlDict How can I let OpenFOAM try to find controlDict file at below? Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers false; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { simple_cylinder.stl { type triSurfaceMesh; name simple_cylinder.stl; } // refinementBox // user defined region // { // type box; // min (-1.0 -0.7 0.0); // max ( 8.0 0.7 2.5); // } } // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 100000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 2000000; // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 10; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells / // nProcs). 0=balance always. maxLoadUnbalance 0.10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 3; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( // { // file "motorBike.eMesh"; // level 6; // } ); Code:
// Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { simple_cylinder.stl { // Surface-wise min and max refinement level level (0 2); // Optional specification of patch type (default is wall). No // constraint types (cyclic, symmetry) etc. are allowed. // patchInfo // { // type wall; // inGroups (motorBikeGroup); // } } } // Resolve sharp angles resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { // refinementBox // { // mode inside; // levels ((1E15 4)); // } } Code:
// Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (50.91234 0.123450001 10.123443); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 2.0; //- Number of mesh displacement relaxation iterations. nSolveIter 30; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 10; //- Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap true; //- Use castellatedMeshControls::features (default = true) explicitFeatureSnap false; //- Detect points on multiple surfaces (only for explicitFeatureSnap) multiRegionFeatureSnap false; } Code:
// Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes true; // Per final patch (so not geometry!) the layer information layers { "(lowerWall|motorBike).*" { nSurfaceLayers 1; } } // Expansion factor for layer mesh expansionRatio 1.0; // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // See relativeSizes parameter. finalLayerThickness 0.3; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.1; // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 1.7.x! (didn't do anything in 1.7.x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 60; // At non-patched sides allow mesh to slip if extrusion direction makes // angle larger than slipFeatureAngle. slipFeatureAngle 30; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 3; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 1; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // Smooth layer thickness over surface patches nSmoothThickness 10; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.3; // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 1.7.x! 90 degrees corresponds to 130 // in 1.7.x. minMedialAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 50; } Code:
// Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { #include "meshQualityDict" // Advanced //- Number of error distribution iterations nSmoothScale 4; //- Amount to scale back displacement at error points errorReduction 0.75; } // Advanced // Write flags writeFlags ( scalarLevels layerSets layerFields // write volScalarField for layer coverage ); // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************************************* // Thank you |
July 5, 2022, 00:50 |
Hasan Celik
Rep Power: 10 |
You have to run snappyHexMesh here:
~/OpenFOAM_files/pipeflow_snappyHexMesh |
July 5, 2022, 01:15 |
#3 | |
Rep Power: 4 |
Traceback (most recent call last): File "/usr/lib/command-not-found", line 28, in <module> from CommandNotFound import CommandNotFound File "/usr/lib/python3/dist-packages/CommandNotFound/CommandNotFound.py", line 19, in <module> from CommandNotFound.db.db import SqliteDatabase File "/usr/lib/python3/dist-packages/CommandNotFound/db/db.py", line 5, in <module> import apt_pkg ImportError: /opt/OpenFOAM/OpenFOAM-v2012/ThirdParty/platforms/linux64/gcc-6.3.0/lib64/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /lib/x86_64-linux-gnu/libapt-pkg.so.6.0) Error in sys.excepthook: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 63, in apport_excepthook from apport.fileutils import likely_packaged, get_recent_crashes File "/usr/lib/python3/dist-packages/apport/__init__.py", line 5, in <module> from apport.report import Report File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in <module> import apport.fileutils File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in <module> from apport.packaging_impl import impl as packaging File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 23, in <module> import apt File "/usr/lib/python3/dist-packages/apt/__init__.py", line 23, in <module> import apt_pkg ImportError: /opt/OpenFOAM/OpenFOAM-v2012/ThirdParty/platforms/linux64/gcc-6.3.0/lib64/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /lib/x86_64-linux-gnu/libapt-pkg.so.6.0) Original exception was: Traceback (most recent call last): File "/usr/lib/command-not-found", line 28, in <module> from CommandNotFound import CommandNotFound File "/usr/lib/python3/dist-packages/CommandNotFound/CommandNotFound.py", line 19, in <module> from CommandNotFound.db.db import SqliteDatabase File "/usr/lib/python3/dist-packages/CommandNotFound/db/db.py", line 5, in <module> import apt_pkg Code:
ImportError: /opt/OpenFOAM/OpenFOAM-v2012/ThirdParty/platforms/linux64/gcc-6.3.0/lib64/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /lib/x86_64-linux-gnu/libapt-pkg.so.6.0) Here is Github link that I've folked. https://github.com/theodoreOnzGit/pi...ppyHexMesh.git |
July 5, 2022, 01:25 |
Hasan Celik
Rep Power: 10 |
Do you have gcc-9 and libstdc++6 on your system? You may need them I guess
July 5, 2022, 02:45 |
#5 | |
Rep Power: 4 |
I had to type snappyHexMesh not snapyHexMeshDict. But because I'm newbie of OpenFOAM, I was confused and typed snapyHexMeshDict. After typing snappyHexMesh properly, then it is solved. Thank you |
controldict, error, snappy hex mesh, system |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
