Paraview of openfoam 9 not recognized by openfoam-2112 |
Michael Jensen
Rep Power: 4 ![]() |
[..this is a continuation, technically, of Modelling a flow contaning a heat conducting object.]
Post-processing gives problems: Code:
eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ paraFoam Invalid $PV_PLUGIN_PATH and -plugin-path= not defined No supplementary ParaView/OpenFOAM reader modules Using builtin reader: paraFoam -vtk /usr/lib/openfoam/openfoam2112/bin/paraFoam: 423: paraview: not found But I already have paraview installed from when I first installed openform.org. This solution: paraFoam command not working (installed openFoam from source + its Third-party) seems closer, but: Code:
eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ paraFoam -built in Error encountered: Unknown option/argument: 'in' See 'paraFoam -help' for usage eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ paraFoam -builtin /usr/lib/openfoam/openfoam2112/bin/paraFoam: 423: paraview: not found Code:
eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ which paraFoam /usr/lib/openfoam/openfoam2112/bin/paraFoam eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ which paraView eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ which paraview eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ Code:
echo $ParaView_DIR Code:
eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ echo $ParaView_DIR eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ Code:
echo $ParaView_LIB_DIR Code:
eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ echo $ParaView_LIB_DIR /opt/paraviewopenfoam56/lib -new information: When I went back to the openfoam 9 tutorials and called paraFoam, it suddenly can't find it anymore. but when I now put in: source /opt/openfoam9/etc/bashrc , it works again. So paraview is there, but switching the source that gets called doesn't "carry" the paraview link along with it.. (I've also now realized that this is in the wrong sub-forum. it should be in "installation". but I don't know how to move it..) Last edited by mikethe1wheelnut; June 10, 2022 at 20:54. Reason: new information |
Yann
Rep Power: 27 ![]() |
Hi Michael,
There are actually 2 OpenFOAM readers for ParaView: the native reader available in ParaView and the one included with OpenFOAM (aka paraFoam). You can load your OpenFOAM cases in ParaView without using paraFoam (actually I did not use paraFoam for years now) In the ESI-OpenCFD branch (openfoam.com) there is a will to get rid of the paraFoam reader to focus on the native reader. They have been working with Kitware do improve the native reader in ParaView-5.10 and this work should keep on going for the next releases. Here is a bit more information (shamelessly took from Mark Olesen posts): https://discourse.paraview.org/t/i-w...uld-i-use/7232 https://develop.openfoam.com/Develop...raview-plugins Regards, Yann |
#3 | |
Michael Jensen
hehe.. I actually recognize those links. ![]() ![]() ![]() |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 26 | June 21, 2024 06:54 |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
[OpenFOAM.com] OpenFOAM 1912 and ParaView 5.6 on CentOS 7 | delsolman | OpenFOAM Installation | 6 | May 7, 2021 13:24 |
[OpenFOAM] ParaView 4.10 and OpenFOAM 2.3.0 Multiregion and decomposed case | romant | ParaView | 3 | April 7, 2014 15:42 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
