Franck
Rep Power: 4 ![]() |
Hello all,
It's my first post here, even if I've read the forum many times. I'm specialized in pollution modeling, and it's been some weeks I have started to use CFD and especially openFoam. I work on a problem and I'd like to have inputs from expert on good practices for my case. I want to model a gas leak from a pipe (methane) on an industrial site. I've tried many things, finally trying to derive the set-up from Fiates & Vianna 2016 ("Numerical Modelling of gas dispersion using openFoam"). I summarize what I did so far : - I run rhoReactingBuoyantFoam - fvScheme : Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { //default none; div(phi,U) Gauss upwind; div(phi,Yi_h) Gauss upwind; div(phi,K) Gauss upwind; div(phi,p) Gauss upwind; div(phi,p_rgh) Gauss upwind; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,omega) Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p_rgh; } wallDist { method meshWave; } Code:
solvers { "(rho|rhoFinal)" { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0; }; p_rgh { solver GAMG; tolerance 1e-5; relTol 0.01; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; }; p_rghFinal { $p_rgh; tolerance 1e-6; relTol 0; }; "(U|Yi|k|h|omega|epsilon)" { solver PBiCG; preconditioner DILU; tolerance 1e-6; relTol 0.1; nSweeps 1; }; "(U|Yi|k|h|omega|epsilon)Final" { $U; tolerance 1e-6; relTol 0; }; } PIMPLE { momemtumPredictor yes; nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 0; } Code:
Final polyMesh/boundary: 5 ( walls { type wall; inGroups 1(wall); nFaces 24582; startFace 2516067; } inletair { type patch; nFaces 945; startFace 2540649; } outlet { type inletOutlet; nFaces 6730; startFace 2541594; faces ( ( 1 2 6 5 ) ( 4 5 6 7 ) ( 0 1 5 4 ) ( 3 2 6 7 ) ); } building { type wall; inGroups 1(wall); nFaces 91942; startFace 2548324; } jet { type inlet; nFaces 4; startFace 2640266; } ![]() - I set-up the boundary conditions for CH4, N2, O2, U...so that to simulate a leak after 25 s of run; example of CH4 file: Code:
FoamFile { version 2.0; format ascii; class volScalarField; object CH4; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 0 0 0 0 0 0 ]; internalField uniform 0; boundaryField { inletair { type fixedValue; value $internalField; } outlet { type inletOutlet; inletValue $internalField; value $internalField; } walls { type zeroGradient; } building { type zeroGradient; } jet { type uniformFixedValue; uniformValue table ( (0.0 0) (25 0) (26 1) (625 1) (626 0) ); } } Now my problems: I tried different things for U as boundary conditions at the jet inlet: a) Directly specifiying the flow speed - If I use a high enough velocity (100 m/s) after 26s of run, i see the creation of the cloud and its further propagation on the site; - If I limit the jet velocity to say 15/25 m/s (given the size of my leak on the mesh, it would correspond to a flow rate of a few hundreds L/min), the cloud remains very small, with very low CH4 concentration, a few cells around the leak only after 90s (I stopped the run here). b) Directly specifying the flow rate with flowRateInletVelocity - With the value I want to simulate (250 L/min, i.e. 4.2e-3 m3/s), same remark as above, almost no CH4 concentration is propagating. Since I am an openFoam newbie, it's highly possible I have made basic errors...I'd be happy to hear from you if you see something wrong in my set-up, or if you have reference works/tutorials about gas leak dispersion with openfoam I have missed. PS: I didn't show eveything (my post seems long to me already...), but I if you need more info on my set-up I'd be happy to share. |
#2 | |
Rep Power: 14 ![]() |
Can I clarify - what do you mean when you say
Do you mean that CH4 concentrations are zero outside of the cells immediately surrounding the source (i.e. the CH4 is definitely not propagating)? If that is the case, check your solver output and the number of iterations that are being done on the CH4 equation. If they have dropped to zero, then adjust your solver tolerances to get the solver working again, or put a minIter line in the fvSolution file for CH4 etc. However, if you mean there is a plume propagating, but that the concentrations are very low, then that's a whole different ballpark. The questions you need to ask youself are: is this correct behaviour (ie should it dilute so quickly)? Have I got enough mesh resolution to resolve the plume (coarse mesh resolution will smear your plume rapidly)? Are my numerical schemes overly diffusive (i.e. generating numerical or false diffusion ... you are using upwind, so the answer is yes)? Hopefully that steers you in the right direction. Getting an appropriate mesh resolution of the pume can be quite a challenge in a "real 3D" scenario. Good luck! |
Franck
Thank you for your answer!
I indeed mean I only have small CH4 concentrations around the leak, but not zero. After a few second, I can reach 1 ppm in the surrounding cells, decreasing very rapidly. My mesh resolution is increased in the jet area, but maybe not enough, so I will definitely check this. I may also have numerical diffusion...by the way, is it possible to check the intensity of numerical diffusion easily? As to if it is a correct behavior...honestly I don't know yet. We have planned a field campaign, but not in the near future. Also, I currently use the same setup for the whole run, but I thought I could first use a steady-state solver to reach an equilibrium in the domain, and then switch to the current set-up with rhoReactingBuoyantFoam and start the leak. This would save me time with my test, but I am not sure I can do it: is it possible to change solver during the run, with the mesh being the same obviously? I think if I start with the latest timestep it should be feasible. What do you think? |
Ah - okay, then I suspect that focussing on the divScheme settings and mesh resolution is probably your best bet.
Upwind differencing (1st order) is nice and stable, but is very diffusive. Try some of the other higher order differencing schemes, but be aware - that may make your run slightly less stable. There's no easy way to identify the numerical error, since to do that you'd need the exact solution ... the simplest way though is to change a parameter and see if it makes a significant difference. On the mesh - this is always the most challenging aspect. Again, the best way to prove to yourself that the mesh is not unduly affecting the solution is to refine the mesh and run again ... and keep going until the changes are negligible (or you run out of comuting resources!). Focus the refinement on the areas that you think are important to resolve accurately (e.g. the jet nozzle, the plume downstream), and add more refinement in there - you should start to see some real improvement. You can use topoSet to grab cells based on their concentration, and refineMesh to refine those cells and then mapFields to map the old solution onto the new mesh (so that you don't have to start the simulation from scratch). Regarding the "correct solution", one of the things that I told my new CFD engineers is that it is always much easier to make a good simulation if you now what the answer should be! That's easy to say of course ... so how to estimate the right answer for your simulation? A field campaign is a great way, but won't help you now. Try looking for simple analogues in the literature (eg jet in a crossflow). You may only find data on velocity, but your plume velocity is a good measure of how your concentration is diluting (they both dilute at roughly the same rate), and so that is okay. Alternatively - look for a simpler plume model (EPA has some, for example; there are commercial models as well like PHAST .. expensive though). A quick run of one of these models will give you a feel for how quickly the plume should dilute. Finally, can you restart a solution with a different solver? Sometimes yes ... providing that the new solver uses all the same variables as the old solver. If it requires new variables, eg p_rgh instead of p, then you may need to spend some time creating the starting files for these variables for the new solver. |
Franck
Thanks for your inputs, I will consider all of your advices to improve my simulation.
how to define surface site density? | Weiqiang Liu | FLUENT | 2 | June 13, 2020 21:13 |
Methane leakage to atmosphere question | hali_pl | FLUENT | 9 | April 7, 2020 10:24 |
Site Species | Diger | FLUENT | 1 | July 23, 2016 09:33 |
Boundary conditions for methane leak into air simulation | RebelLion | OpenFOAM Running, Solving & CFD | 2 | April 6, 2016 11:58 |
Methane Combustion | Lars | FLUENT | 4 | March 5, 2003 08:24 |
