Different behaviour of interFoam across versions
Like Tree1Likes
  • 1 Post By mrishi
Old   June 8, 2022, 06:27
Exclamation Different behaviour of interFoam across versions
Rishikesh
mrishi is on a distinguished road
I have been observing strange artificial oscillations in my interFoam based simulations. So to isolate the issue I set up a cylinder domain half filled with water. No initial velocities anywhere, no inlets, only a pressure outlet at the top of cylinders and walls everywhere.
I expected this to remain stationary. But when I solved interFoam on this, I see that numerically induced velocities occur near the interface, which can be seen in the attached figure.
In the figure above: frame 1 is ESI solution (v2006), frame 2 (top right) is OF-9, frame 3 is OF-6 and the 4th quadrant shows that mesh is same along with a photo of the overall domain.
Most interestingly the oscillations has grid sensitive pattern, which is very strong in Foundation simulations (v6 and v9), and much better behaved in ESI version simulations (v2006). I though this has to do with compression term of interFoam. In the figures, vanLeer scheme with cAlpha=1 has been used. cAlpha is a suspected culprit for introducing oscillations but removing it fudges the interface, and even with it switched on, there is distinct difference between the two forks' behaviour, which is particularly bothersome. To state explicitly, the ESI version handles numerical oscillation much better than Foundation, with v9 performing the worst.
Since the cAlpha compression term is a feature of algebraic VOF, I also tried the alternative - geometric VOF. For ESI this was the interIsoFoam, where results were also similar to ESI interFoam (with different, small magnitude oscillations). On the other hand, the new geometric VOF scheme in v9 (MPLIC) has similarly poor behaviour as algebraic scheme above.
If there were to be motion in this mesh, the v9 interface will oscillate wildly over time, which may go unnoticed if the domain is not neatly ordered, as it is in this case. In the context of this motion, it is worth noting that the presence of turbulence increases these oscillations, but they do occur even without it, going from better to worse going from cAlpha 0 to cAlpha 1, and laminar to turbulence. The former can be somewhat tricky to test with the vanLeer scheme, since it is quite diffusive. So I checked with the CICSAM scheme by Ubbink and Isaa.
In general, OF-9 has by far the worst performance, even though the cases are set up identically, and I would like to understand why this is happening. Can we somehow improve the solution, or check for obvious mistakes, so as to get consistent solution from all these solvers, since this is a fairly simple case setup and a fairly standard solver?
Also may be worth noting that the solution does not converge to very low residuals (modeled using laminar flow), when using PISO and diverges if using PIMPLE loops. I checked this because maybe the insufficient convergence of single outer loop was causing spurious oscillations, but then I found that having multiple loops leads to divergence after a few timesteps.
Can someone kindly point me in the obvious direction about this?
lourencosm likes this.
Last edited by mrishi; June 8, 2022 at 18:36. Reason: additional clarification and elaboration.
mrishi is offline   Reply With Quote
Old   June 10, 2022, 19:32
Paulo Vatavuk
vatavuk is on a distinguished road
Dear mrishi,
This thread may contain information related to your problem:
InterFoam: Different results in OF5 and OF6
Observe that the time derivative calculation in ddtScheme is different in version 6. In version 7 the changes were reverted and it is the same as in version 5. This may explain the differences between versions 6 and 9, but I have no idea why v2006 performs better.
I hope this helps.
vatavuk is offline   Reply With Quote
esi openfoam, foundation, interfoam
interFoam two-phase pipe flow air phase behaviour katete OpenFOAM Running, Solving & CFD 11 February 3, 2021 04:14
k-e & GAMG interFoam Schemitisation Stability Issue JFM OpenFOAM Running, Solving & CFD 3 December 1, 2015 06:58
strange pressure behaviour with symmetricPlane boudary condition - interFoam duongquaphim OpenFOAM Running, Solving & CFD 10 August 20, 2013 15:00
Strange boundary behaviour using interFoam Andrea_85 OpenFOAM 11 January 22, 2013 16:09
divergence behaviour of interFoam solver for very fine mesh purushotam85 OpenFOAM Running, Solving & CFD 0 June 23, 2010 19:57
