Modelling a flow contaning a heat conducting object. |
June 7, 2022, 20:38 |
Michael Jensen
Rep Power: 4 |
This is a trial shot to see if anybody can offer guidance. Say I want to model the flow of air inside a chimney. Inside this same chimney is a butterfly valve. Say at 45 degrees. So far, fairly simple, just modify the airfoil tutorial. Say though, that the valve is thin, and conducting. Made of aluminum foil for some reason. So that heat from the up-stream side can pass through it and get transmitted to the air on the downstream side. Can openfoam (.org in my case) do this? Would it be easier/better to model it as a solid object (or inflated object?), or as a zero-thickness wall? A wall that prevents molecules from passing through, but transmits heat? (I don't know how to do either of these things -guidance to relevant tutorials is totally appreciated -I'll keep looking in the meantime :-) )
Things that look promissing..: http://www.tfd.chalmers.se/~hani/kur...eport_Turo.pdf https://www.youtube.com/watch?v=5z5Jix6tZAk ..looks like chtMultiRegionFoam might be the solution, or part of it.. |
June 9, 2022, 04:42 |
#2 | |
Michael Jensen
Rep Power: 4 |
I've made it much further through my study now, and technically, I believe the tutorial referenced above can solve the problem. That said, implementing it will be cumbersome, awkward, and limited. I believe there is a better way, combining it with snappyHexMesh (like in the air-foil simulation). I've seen the following referenced in a few places: $FOAM_TUTORIALS/mesh/snappyHexMesh/snappyMultiRegionHeater. However, I don't have it. I suspect it is a tutorial of openform[.com] instead of openfoam[.org]. Is there something equivalent for .org? |
June 9, 2022, 17:55 |
Michael Jensen
Rep Power: 4 |
Finally some actual problems. :-)
I've now downloaded openFoam from the .com website and got the directories organized (I think) the way I'm supposed to. Note that I already did this exact same process with openFoam from the .org website, so that might be causing some problems, not sure. So, here is a list of the errors I'm getting (from running the tutorial /mesh/snappyHexMesh/snappyMultiRegionHeater), extracted from the full terminal output provided at the end. :-) First problem: Code:
-decomposeParDict already run on /home/eriadar/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater: remove log file 'log.-decomposeParDict' to re-run Second Problem: Code:
./Allrun: 24: restore0Dir: not found Code:
foamListRegions: symbol lookup error: foamListRegions: undefined symbol: _ZN4Foam7argList13argsMandatoryEv Full terminal output: Code:
eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ ls 0.orig Allclean Allrun Allrun-parallel Allrun-serial constant system eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ ./Allrun Running blockMesh on /home/eriadar/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater Running surfaceFeatureExtract on /home/eriadar/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater Running -decomposeParDict on /home/eriadar/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater -decomposeParDict already run on /home/eriadar/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater: remove log file 'log.-decomposeParDict' to re-run ./Allrun: 24: restore0Dir: not found -decomposeParDict already run on /home/eriadar/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater: remove log file 'log.-decomposeParDict' to re-run foamListRegions: symbol lookup error: foamListRegions: undefined symbol: _ZN4Foam7argList13argsMandatoryEv foamListRegions: symbol lookup error: foamListRegions: undefined symbol: _ZN4Foam7argList13argsMandatoryEv foamListRegions: symbol lookup error: foamListRegions: undefined symbol: _ZN4Foam7argList13argsMandatoryEv Running chtMultiRegionFoam in parallel on /home/eriadar/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater using 4 processes foamListRegions: symbol lookup error: foamListRegions: undefined symbol: _ZN4Foam7argList13argsMandatoryEv Use paraFoam -touch-all to create files for paraview post-processing eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ paraFoam -touch-all unknown option/argument: '-touch-all' Usage: paraFoam [OPTION] [PARAVIEW_OPTION] options: -block use blockMesh reader (uses .blockMesh extension) -builtin use VTK builtin OpenFOAM reader (uses .foam extension) -case <dir> specify alternative case directory, default is the cwd -empty launch ParaView without opening any data files -region <name> specify alternative mesh region -touch only create the file (eg, .blockMesh, .OpenFOAM, etc) -touchAll create .blockMesh, .OpenFOAM files (and for all regions) -help print the usage paraview options start with a double dashes * start paraview 5.6.0 with the OpenFOAM libraries eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ paraFoam -touchAll Created 'snappyMultiRegionHeater.blockMesh' Created 'snappyMultiRegionHeater.OpenFOAM' eriadar@eriadar-Latitude-E7440:~/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater$ paraFoam I/O : uncollated --> FOAM FATAL IO ERROR: adjustable is not in enumeration: 5 ( adjustableRunTime clockTime cpuTime runTime timeStep ) file: /home/eriadar/OpenFOAM/eriadar-2112/run/tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater/system/controlDict/writeControl at line 29. From function Enum Foam::NamedEnum<Enum, nEnum>::read(Foam::Istream&) const [with Enum = Foam::Time::writeControl; unsigned int nEnum = 5] in file lnInclude/NamedEnum.C at line 69. FOAM exiting |
June 10, 2022, 05:14 |
Yann
Rep Power: 29 |
Hi Michael,
My best bet would be that you are trying to run a ".com" tutorial with a ".org" openfoam version. You can check this by typing the command foamVersion in your terminal. It will tell you which version you are currently using. You can change version with this command: OpenFOAM-v2112 Code:
source /usr/lib/openfoam/openfoam2112/etc/bashrc Code:
source /opt/openfoam9/etc/bashrc You can have as many OpenFOAM versions as you want installed on your system and you can use the source command to switch versions. In order to load the OpenFOAM environment at login, you can also add the source command in the user's bashrc file located there : /home/username/.bashrc. This is probably what you have done when installing OpenFOAM-9 since this is what is explained in the installation procedure under the "User Configuration" section: https://openfoam.org/download/9-ubuntu/ I hope this helps, Yann |
June 10, 2022, 14:43 |
#5 | |
Michael Jensen
Rep Power: 4 |
I expect it will. Clearly, I got some parts of the installation procedure right, but didn't follow -all- the instructions. Specifically, the following: (https://develop.openfoam.com/Develop.../wikis/running) Code:
Manually To manually activate a particular OpenFOAM version, source its corresponding etc/bashrc file: $ . /path/to/openfoam/etc/bashrc After using the desired OpenFOAM commands, the wmUnset alias can be used to remove it again. The instructions for a persistent session are similar. Code:
Manual For a persistent OpenFOAM environment, the OpenFOAM bashrc file can be sourced from your ~/.bashrc file by adding a line resembling the following to that file: . /path/to/openfoam/etc/bashrc It is usually prudent to check the existence of the file prior to sourcing it: if [ -f /path/to/openfoam/etc/bashrc ] then . /path/to/openfoam/etc/bashrc fi I believe what I had done was assume that since I was in the sub-folder of the tutorials of a specific version, that "it" would automatically recognize that fact, and use the correct program. Incorrect, clearly |
June 10, 2022, 15:45 |
#6 | |
Michael Jensen
Rep Power: 4 |
Looks like it worked! Many thanks! However, post-processing gives trouble.. submitting that as a different thread so it's more useful for others.. (Paraview of openfoam 9 not recognized by openfoam-2112) |
heat diffusion, multi-component, openfoam 9 |
[foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 15:56 |
Coursework - Basic questions | LBOstudent | Phoenics | 1 | December 18, 2015 06:39 |
Geothermal Reservoir 2D heat flow modelling | phobo | ANSYS | 0 | May 25, 2014 11:10 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
