multiComponentMixture - Combustion with OpenFoam
Like Tree3Likes
  • 1 Post By Ale22pic
  • 1 Post By ade10
  • 1 Post By ade10
Old   May 23, 2022, 07:53
Default multiComponentMixture - Combustion with OpenFoam
ade10 is on a distinguished road
Hi to everyone,
i'm having a problem with OF especially with the combustion case with the tool reactingFoam. i'm trying to do this tutorials (https://develop.openfoam.com/Develop.../RAS/DLR_A_LTS) but OF gives me an error:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 9
\\/ M anipulation |
Build : 9-b456138dc4bc
Exec : reactingFoam
Date : May 23 2022
Time : 10:33:45
Host : "7a5db86db9cd"
PID : 1143
I/O : uncollated
Case : /home/openfoam/combustion/SandiaD_LTS
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: No convergence criteria found
PIMPLE: Operating solver in transient mode with 1 outer corrector
PIMPLE: Operating solver in PISO mode
Using LTS
Reading thermophysical properties
Selecting thermodynamics package
type hePsiThermo;
mixture multiComponentMixture;
transport sutherland;
thermo janaf;
energy sensibleEnthalpy;
equationOfState perfectGas;
specie specie;
--> FOAM FATAL IO ERROR:
keyword species is undefined in dictionary "/home/openfoam/combustion/SandiaD_LTS/constant/thermophysicalProperties"
file: /home/openfoam/combustion/SandiaD_LTS/constant/thermophysicalProperties from line 19 to line 32.
From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
in file db/dictionary/dictionary.C at line 831.
FOAM exiting
does anyone know why?
thnks to all that will answer me
ade10 is offline   Reply With Quote
Old   May 23, 2022, 09:21
Alessio Piccolo
Ale22pic is on a distinguished road
Hi ade10, I think that the problem is due to how you write the entries in thermophysical properties since you are using V9 and the tutorial is from V2112. I suggest to check in V9 tutorial folder for the same case and seeing how they write down the entries. Let me know.
Ale22pic is offline   Reply With Quote
Old   June 28, 2022, 18:46
ET3
Erik T
ET3 is on a distinguished road
Hi ade10,
Did you solve this problem? I am stuck on it too.
The tutorials I am using have outdated mixture commands, but updating to multiComponentMixture was straightforward.
The "keyword specie is undefined in dictionary...." error persists.
For what it's worth, I am using the tutorials that came with my installation.
Thank you,
Erik
ET3 is offline   Reply With Quote
Old   June 29, 2022, 03:33
Alessio Piccolo
Originally Posted by ET3 View Post
Hi ade10,
Thank you,
Erik
Hi Erik, can you show as the thermo physical properties files and tell also which tutorial and version are you using?
ET3 likes this.
Old   June 29, 2022, 05:06
Default Resolved
Hi ade10,
Thank you,
Erik
Hi Erik,
yes i've solved the problem.... I was using of.org and it wants some things written differently from of.com
you can try this:
\\/ M anipulation |
FoamFile
format ascii;
class dictionary;
location "constant";
object thermophysicalProperties;
thermoType
type hePsiThermo;
thermo janaf;
specie specie;
defaultSpecie N2;
#include "thermo.compressibleGasGRI"
ET3 likes this.
Old   June 29, 2022, 11:51
ET3
Erik T
Hi Alessio,
Thank you for the response!
I am trying the tutorial counterFlowFlame2DLTS.
I think I may be confused about which version I am using. When I run blockMesh, it says version 9 :
\\/ M anipulation |
But my tutorials are for v2106. Below is the thermoPhysicalProperties file.
Based on ade10's reply, I learned that there are two different "flavors" of openfoam. Are there compelling reasons to use one over the other?
| \\ / O peration | Version: v2106 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
thermoType
type heRhoThermo;
thermo janaf;
specie specie;
inertSpecie N2;
chemistryReader foamChemistryReader;
foamChemistryFile "<constant>/reactions";
foamChemistryThermoFile "constant/thermo.compressibleGas";
Old   June 29, 2022, 13:21
hi the include functions can be different from of.com to of.org
try to download and launch this one
https://github.com/AleOfMan/OpenFoamTutorial.git
ET3 likes this.
combustion, openfoam, reactingfoam, thermophysicalproperties
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
Two-day Meeting on Internal Combustion Engine Simulations Using OpenFOAM Technology lucchini OpenFOAM Announcements from Other Sources 1 October 21, 2015 17:16
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
