RotatingFanInRoom tutorial with OpenFoam9 error
Like Tree1Likes
  • 1 Post By gart04
Old   May 13, 2022, 08:56
Default RotatingFanInRoom tutorial with OpenFoam9 error
gart04 is on a distinguished road
Hi
I'm trying to run RotatingFanInRoom tutorial with OpenFoam9. I'v got a strange error message and i did not find the solution, p field is not wrote but why ...
My call :
surfaceFeatures (no problem)
blockMesh (no problem)
snappyHexMesh -overwrite (no problem)
renumberMesh -overwrite (no problem)
pimpleFoam (problem ==>
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: solidBody
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone rotatingZone
PIMPLE: No convergence criteria found
PIMPLE: No corrector convergence criteria found
Calculations will do 3 corrections
PIMPLE: Operating solver in transient mode with 3 outer correctors
Reading field p
--> FOAM FATAL ERROR:
cannot find file "/home/nico/rotatingFanInRoom/mesh/0/p"
From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 539.
FOAM exiting
Thanks a lot
gart04 is offline   Reply With Quote
Old   May 13, 2022, 10:02
Yann
Yann will become famous soon enoughYann will become famous soon enough
Lets start with the obvious, since you get this:
Do you have a 0 directory in your case and does it contain a "p" file?
Your path looks a bit odd, do you run the pimpleFoam command from the "mesh" directory? (/home/nico/rotatingFanInRoom/mesh)
Regards,
Yann
Yann is offline   Reply With Quote
Old   May 13, 2022, 10:14
Hi Yann
thanks for your help. Yes i check all the obvious criteria i think : i run pimpleFoam from the mesh directory and i have not the /0 directory, but i assume it was creating automatically by the run and this is what causes the error. Maybe my mystake is i have to create the /0 folder "manually" before running pimpleFoam ? I usually use AcuSolve solver from Hypermesh for CFD, i just begin to use OpenFoam.
Thank you again
Old   May 13, 2022, 10:22
Ok i check, all my set (P,U,K,omega,nut) in 0 directory directly copied in mesh directory and it works (i have other errors but i work on it). I thought that was done automatically with my 0.orig. Very obvious you are right, thanks again. Yann
Yann likes this.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 07:45
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
