forwardStep tutorial case: failure in OpenFOAM-dev using rhoPimpleFoam |
May 3, 2022, 17:27 |
#1 | |
Robert C
I am new to OpenFOAM, and am experimenting with various flavors of the solver, including OpenFOAM-6 and OpenFOAM-dev (CFD-Direct), and OpenFOAM-plus (ESI).
I am interested in compressible solvers, so for OpenFOAM-dev, I attemped to run the forward step problem ($FOAM_PROJECT_DIR/tutorials/compressible/rhoPimpleFoam/laminar/forwardStep) using rhoCentralFoam and rhoPimpleFoam. To my surprise, rhoPimpleFoam failed with the below error message. I am posting here to see if I am missing something simple, ahead of filing a bug report with CFD Direct. I greatly appreciate any help you can provide. Code:
Courant Number mean: 0.251275 max: 1.17915 Time = 0.016s PIMPLE: Iteration 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 0.0764808, Final residual = 1.29e-06, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.064002, Final residual = 7.94223e-06, No Iterations 1 smoothSolver: Solving for e, Initial residual = 0.26368, Final residual = 4.9006e-06, No Iterations 3 smoothSolver: Solving for p, Initial residual = 0.0715941, Final residual = 6.77228e-08, No Iterations 2 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.94255e-09, global = 1.06042e-09, cumulative = 6.6211e-09 PIMPLE: Iteration 2 smoothSolver: Solving for Ux, Initial residual = 0.00795199, Final residual = 9.99449e-11, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.021992, Final residual = 1.56364e-09, No Iterations 1 smoothSolver: Solving for e, Initial residual = 0.285134, Final residual = 2.3536e-08, No Iterations 2 --> FOAM FATAL ERROR: Negative initial temperature T0: -3.09503 Looking at the git log, I see the following commit which may be related: Quote:
FWIW, I am using OpenFOAM-dev at commit 38262243ccdd13bd936541d2373ccfd1974db597 Last edited by RobertC; May 4, 2022 at 10:36. |
September 12, 2022, 13:23 |
jay
I concur that this case, as packaged in OpenFOAM 10 (installed 1 or 2 months ago from CFD Direct), encounters the negative temperature error. I can overcome the error when adding the following lines to the file 'system/controlDict'.
adjustTimeStep yes; maxCo 0.7; maxDeltaT 1; However, the process time step becomes very small, ~2e-08. |
September 12, 2022, 14:44 |
Use limiter on T using https://www.openfoam.com/documentati...mperature.html
Nothing in rhoSimpleFoam prevents negative T values, especially in initial stages of convergence. The issues has been repeated discussed in this forum. Good luck. |
June 17, 2023, 12:29 |
jay
The issue I had was addressed by OpenFOAM.org Issue 3889.
compressible, pimple, tutorial |
[Tutorials] How to prepare a case for OpenFOAM (for beginners) | taalf | OpenFOAM Community Contributions | 1 | November 6, 2022 02:22 |
Sandia Flame D OpenFoam tutorial case - bad result? | Brandani | OpenFOAM Programming & Development | 8 | January 18, 2022 14:29 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 09:51 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 06:40 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
