Getting negative temperatures after repeating simulation |
April 18, 2022, 17:21 |
Ignacio Z
Rep Power: 4 |
I am using rhoCentralFoam for my PhD project and I am still learning how to use it properly. The flow is a supersonic jet with shockwaves. After getting a somewhat succesful siumulation I tried doing more with different conditions, but kept getting negative temperatures, and the simulation was killed. I tried retracing my steps and I am now trying to run the same case I had already gotten a solution from, and I am getting negative temperatures after only a few timesteps. Is this an issue anyone has encountered? Why would running the same case twice give a completely different outcome? I am using rhoCentralFoam and running in parallel with mpirun. Reagrds, Nacho |
April 20, 2022, 03:20 |
Rep Power: 14 |
That's a good question - and the simple answer is that it wouldn't. The longer answer would include "... provided that everything was the same". Check your boundary conditions, solver settings etc. and you will probably find a difference in there somewhere.
April 20, 2022, 16:04 |
Ignacio Z
Rep Power: 4 |
Hi Tobermory,
You were right, I had a decimal point on the wrong place in the U file. Thank you |
negative temperature, rhocentralfoam, supersonic jet |
Simulation of the Negative pressure generated by a 3d model of flexible bellow | marten363 | OpenFOAM | 0 | December 9, 2021 06:00 |
sonicFoam - simulation stop for negative temperature - are my parameters wrong ? | Jad.L. | OpenFOAM Running, Solving & CFD | 0 | December 24, 2018 17:08 |
Transient Simulation in CFX | ashtonJ | CFX | 1 | September 28, 2018 01:18 |
what is reason of negative moment in simulation? | aja1345 | FLUENT | 1 | July 20, 2018 20:10 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
