Ignition in combustion
Like Tree3Likes
  • 2 Post By PaleliSooraj
  • 1 Post By überschwupper
Old   April 4, 2022, 11:59
Default Ignition in combustion
ajithnair's Avatar
Ajith U K Nair
ajithnair is on a distinguished road
Hi Foamers
How can we provide an ignition source in combustion which lasts for only few seconds till the charge ignites.
I have tried setting high temperature for internal field but the flame just ignites on entry itself. Is there a way to give high temperature patch?
ajithnair is offline   Reply With Quote
Old   April 6, 2022, 09:28
PaleliSooraj is on a distinguished road
You can use a volumetric heat source for creating high temperature patch using fvOptions or setFieldsDict. Time of ignition can be mentioned there.
BIRAJ and ajithnair like this.
PaleliSooraj is offline   Reply With Quote
Old   May 4, 2022, 03:06
überschwupper is on a distinguished road
As an example:
fvModels (since OFv9 )
ignition
    type             heatSource;//semiImplicitSource;
    selectionMode    cellSet;
    cellSet            ignition;
    volumeMode        absolute; //absolute
    q
        type scale;
        scale squarePulse;
        start 0.0005;
        duration 0.001;
        value 1e+8;
    /*sources
        Qign
            // type             semiImplicitSource;
            // name             heatInjection;
            // selectionMode     cellSet;
            // cellSet         ignition;
            // volumeMode        specific;
            // timeStart        0.001;
            // duration        0.01;
            explicit 10e+7;
            implicit 0; //{}
and topoSetDict
actions
        name ignition;//ignitionCells;
        type cellSet;
        action new;
        source cylinderToCell; // or whatever
        sourceInfo
            p1          (x y z);
            p2            (x y z);
            radius          1e-2; //outer radius
            innerRadius        0;    //default 0
acgnipper likes this.
überschwupper is offline   Reply With Quote
Old   May 5, 2022, 03:09
ajithnair's Avatar
Ajith U K Nair
Thankyou. the volumetric heat source idea worked. It was given using fvModels.(i am using openfoam dev, ofv9 should also have this. earlier versions it was under a file called fvOptions)
combustion, ignition, methane combustion, patch by zone, reacting foam
Combustion Simulation ANSYS Fluent - There is no ignition delay Rudolf Diesel FLUENT 1 May 21, 2023 07:30
Combustion Simulation ANSYS Fluent - There is no ignition delay Rudolf Diesel FLUENT 2 October 1, 2018 02:16
Combustion in Spark Ignition Cylinder tom634 FLUENT 1 December 30, 2014 12:45
Add ignition but combustion does not occur IColin OpenFOAM Running, Solving & CFD 3 January 19, 2014 02:43
how does the ignition model initiate main combustion mepgzzi Siemens 0 June 23, 2012 15:32
