Relaxation Factor in Combustion
Like Tree2Likes
  • 2 Post By piu58
Old   March 18, 2022, 00:47
Default Relaxation Factor in Combustion
ajithnair's Avatar
Ajith U K Nair
ajithnair is on a distinguished road
Will adding relaxationFactor in fvSolution affect the accuracy of solution? If so what is a safe value of relaxation factor.
I am doing a simulation on methane combustion in a Archemedian spiral channel and by changing relaxationFactors the result keeps changing. The flame stabilizes at different locations just by changing the relaxationFactor. Results are only obtained for relaxationFactor < 0.7. Any value above it causes the chemical time step to increase to an order on e-11 and solution diverges.
relaxationFactors
equations
".*" 0.5;
ajithnair is offline   Reply With Quote
Old   March 18, 2022, 01:24
ajithnair's Avatar
Ajith U K Nair
I found some material about relaxation factor here
https://www.simscale.com/docs/simula...ation-factors/
relaxationFactors
equations
".*" 0.5;
Old   March 18, 2022, 04:33
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Relaxation should not influence a steady state result. If your case is straightforward and relaxation is not necessary: Introducing it increases calculation time, nothing else.
In transient simulations under-relaxation acts as some kind of slow motion and may be smear effects.
Amirreza_pro and ajithnair like this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
combustion modeling, diverging solution, fvsolution, reactingfoam;, relaxationfactor
energy under relaxation factor in combustion simulation Weiqiang Liu FLUENT 0 May 19, 2020 08:17
Lets talk about relaxation factor optimization chriss85 OpenFOAM Running, Solving & CFD 35 June 21, 2019 10:54
Long output in terminal. ssa_cfd OpenFOAM Running, Solving & CFD 1 March 18, 2019 06:25
relaxation factors for combustion solutions hnemati FLUENT 1 January 7, 2019 23:23
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 05:10
