Getting weird pressure distribution and backflow with chtMultiRegionFoam |
March 17, 2022, 19:29 |
Rep Power: 4 |
Hi! I'm new to OpenFoam and I'm trying to simulate laminar flow inside a pipe with heat transfer, using a 2D geometry. Initially I was able to simulate the flow without heat transfer using simpleFoam, but when trying to implement it into chtMultiRegionFoam even with constant temperature I get strange results. There's a zone in the wall with -5.3e4 Pa and having back flow. I've been trying different things the whole day with no results, so I'm posting here.
Here's the folder with what I have: https://drive.google.com/drive/folde...AY?usp=sharing Photos: https://imgur.com/a/50LZVhL |
March 18, 2022, 02:33 |
Ajith U K Nair
Rep Power: 5 |
it might be your boundary conditions. Also there is only one fluid region inside the case setup. Where is the heat getting transferred to. Is here any pipe wall or solid material or another region. I could only see one region
March 18, 2022, 09:15 |
#3 | |
Rep Power: 4 |
Yes there is only one fluid region. I applied the boundary condition:
March 18, 2022, 11:57 |
Uwe Pilz
Rep Power: 15 |
I used
p type zeroGradient; U type fixedValue; value uniform (0 0 0); p_rgh type fixedFluxPressure; gradient uniform 0; T type fixedValue; value uniform 301; kappa type kqRWallFunction; value uniform 0.0; alphat type alphatJayatillekeWallFunction; Prt 0.85; value uniform 0; nut type nutkWallFunction; value uniform 0;
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
chtmultiregionfoam |
chtMultiRegionFoam and porous media | vainilreb | OpenFOAM Running, Solving & CFD | 4 | April 12, 2023 09:59 |
Pressure outlet BC help! | eishinsnsayshin | FLUENT | 7 | December 4, 2012 00:36 |
Swirl in backflow on pressure outlets | Jonas Larsson | FLUENT | 17 | February 3, 2000 03:14 |
