March 17, 2022, 05:46 |
Sandia Flame D with C2H4 (Ethylene)
Amirreza Niazmehr
Rep Power: 7 |
Hi guys,
I hope that you are doing well. I'm using Sandia Flame D (SandiaD_LTS) tutorial. This test case is by default for methane (CH4). If I'm going to change the fuel and use Ethylene (C2H4) instead of it, what should I do? Dos anyone have any idea? All the bests Amirreza |
March 17, 2022, 09:52 |
#3 | |
Amirreza Niazmehr
Rep Power: 7 |
I replaced reaction mechanism for CH4 in "reactions" file by reaction mechanism for C2H4 like below: PHP Code:
PHP Code:
March 17, 2022, 23:56 |
Ajith U K Nair
Rep Power: 5 |
If you are planing to do multi step reaction modelling you can import reaction mechanism from chemkin using chemkinToFoam. This thread may help.
how to use chemkinToFoam ? |
March 18, 2022, 07:05 |
#5 | |
Amirreza Niazmehr
Rep Power: 7 |
I have already converted it with chemkinToFoam succesfully. My question is, in this case that I'm going to use C2H4 (Ethylane), then in which files I should implement these changes (modifications)? For example should I change also the files in "0.Floder" (which is for initial conditions). I don't know where actually I should interduce C2H4 (Ethylane) as the fuel and where (in which files) should I implement these changes. I got a little confused for that |
March 19, 2022, 11:21 |
Amirreza Niazmehr
Rep Power: 7 |
Hi guys !
I found out how to modify the files in the case that you are going to change the fuel and use for example Ethylene instead of Methane in your simulation If someone has in the future questions about it, just write here or send me a PV. All the best Last edited by Amirreza_pro; March 20, 2022 at 01:00. |
March 20, 2022, 07:46 |
Amirreza Niazmehr
Rep Power: 7 |
Hi sure, I can send you the results. Just send me your email in PV.
I should also mention, the main reason that we canged the fuel was that with methane we could not get sufficient soot, therefore we decided to change the fuel from Methane to Ethylane and also change the ratio of Fuel-Air in the main jet in oder to get considerable mount of soot. Now we are getting very nice results. All the best |
September 16, 2022, 07:32 |
#9 | |
Arthur
Rep Power: 12 |
Hi! In my opinion you should also change the Arrhenius coefficients. Did you find the correct coefficients for the "C2H4 + 3O2 + 11.28N2 = 2CO2 + 2H2O + 11.28N2" reaction? |
Sandia Flame D OpenFoam tutorial case - bad result? | Brandani | OpenFOAM Programming & Development | 8 | January 18, 2022 13:29 |
[Other] Meshing for Sandia Flame D | FlameKan | OpenFOAM Meshing & Mesh Conversion | 2 | February 21, 2019 21:51 |
[ANSYS Meshing] 2D Mesh for Sandia Flame D | FlameKan | ANSYS Meshing & Geometry | 2 | February 21, 2019 21:43 |
How to set the Reynolds number up for a turbulent Jet flame (Sandia D) | miri | OpenFOAM | 0 | May 24, 2015 10:38 |
Modeling the Sandia flame D with EDC | Christoph_84 | FLUENT | 1 | September 18, 2011 20:24 |
