Natural convection on a vertical cylinder
Like Tree2Likes
  • 1 Post By Roman1
  • 1 Post By piu58
Old   March 16, 2022, 15:53
Question Natural convection on a vertical cylinder
Roxana Laspiur
Roxana_Laspiur is on a distinguished road
Hi!
I am new to OpenFoam. I am trying to simulate internal natural convection on a vertical cylinder, but I have a problem with the result. I am working with the buoyantBoussinesqPimpleFoam solver (transient case).
A time large (approx 30 min) quasi-steady, I get a full stratified fluid full but streamlines aren't expected (toroidal shape). I also compared the vertical velocity with radius, with a paper by Hess and Miller, did not come up to expectations.
I think my problem is in the Dict of fvSolution and fvSchemes.
I am working in the laminar regime Ra=10¹⁰.
BC:
  • wall top and bottom isolated
  • sidewall T= 296 K
Fluid is water and T_0= 293 K
Attached are the Dict and images of the T-profile and the streamlines.
Thanks for your help and sorry for my English.
blockMeshDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
//lado del cuadrado interno
l          0.30;
nl        -0.30;
s          0.35;
sn        -0.35; //longitud de la curvatura del cuadrado interior
// datos del cilindro
R           0.5;  //radio
Rn         -0.5;
H           1;  //altura
//arcos del cilindro
X           0.353553;  //x=R*cos 45º
Xn         -0.353553;
Z           0.353553;  //z
Zn         -0.353553;
scale        1 ;
vertices
    //Cuadrado interior
    ($l  0 $l)  //0
    ($nl 0 $l) //1
    ($nl 0 $nl)//2
    ($l  0 $nl) //3
    ($l  $H $l)  //4
    ($nl $H $l) //5
    ($nl $H $nl)//6
    ($l  $H $nl) //7
    //cilindro externo
    ($X 0 $Z)   //8
    ($X 0 $Zn)  //9
    ($Xn 0 $Zn) //10
    ($Xn 0 $Z)  //11
    ($X $H $Z)   //12
    ($X $H $Zn)  //13
    ($Xn $H $Zn) //14
    ($Xn $H $Z)  //15
blocks
    hex (0 3 2 1 4 7 6 5) (20 20 35) simpleGrading (1 1 1)
    //block 1
    hex (8 9 3 0 12 13 7 4) (20 10 35) simpleGrading (1 4 1)
    //block 2
    hex (9 10 2 3 13 14 6 7) (20 10 35) simpleGrading (1 4 1)
    //block 3
    hex (10 11 1 2 14 15 5 6) (20 10 35) simpleGrading (1 4 1)
    //block 4
    hex (11 8 0 1 15 12 4 5) (20 10 35) simpleGrading (1 4 1)
edges
    arc 0 1 (0 0 $s)
    arc 1 2 ($sn 0 0)
    arc 2 3 (0 0 $sn)
    arc 3 0 ($s 0 0)
    arc 4 5 (0 $H $s)
    arc 5 6 ($sn $H 0)
    arc 6 7 (0 $H $sn)
    arc 7 4 ($s $H 0)
    //cilindro externo
    arc 8 9   ($R 0 0)
    arc 9 10  (0 0 $Rn)
    arc 10 11 ($Rn 0 0)
    arc 11 8  (0 0 $R)
    arc 12 13 ($R $H 0)
    arc 13 14 (0 $H $Rn)
    arc 14 15 ($Rn $H 0)
    arc 15 12 (0 $H $R)
boundary
    wallTop
        type wall;
        faces
            (4 7 6 5)
            (12 13 7 4)
            (13 14 6 7)
            (14 15 5 6)
            (15 12 4 5)
    wallDown
        type wall;
        faces
            (0 1 2 3)
            (8 9 0 3)
            (10 9 3 2)
            (10 2 1 11)
            (1 0 8 11)
    sides
        type wall;
        faces
            (11 8 12 15)
            (10 11 15 14)
            (9 10 14 13)
            (8 9 13 12)
ControlDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     buoyantBoussinesqPimpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         3000;
deltaT          0.03;
writeControl    timeStep;
writeInterval   1000;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  no;
maxCo           0.5;
functions
    #includeFunc singleGraph1
    #includeFunc singleGraph2
fvSchemes:
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss QUICK; //upwind
    div(phi,T)      Gauss QUICK; //upwind
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(phi,R)      Gauss upwind;
    div(R)          Gauss linear;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         uncorrected;
fvSolution:
solvers
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-6;
        relTol          0.01;
    p_rghFinal
        $p_rgh;
        relTol          0;
    "(U|T|k|epsilon|R)"
        solver          PBiCGStab;
        preconditioner  DILU;
        tolerance       1e-6;
        relTol          0.1;
    "(U|T|k|epsilon|R)Final"
        $U;
        relTol          0;
PIMPLE
    momentumPredictor no;
    nOuterCorrectors 1;
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
relaxationFactors
    equations
        "(U|T|k|epsilon|R)" 1;
        "(U|T|k|epsilon|R)Final" 1;
Roxana_Laspiur is offline   Reply With Quote
Old   March 17, 2022, 04:31
Roman
Roman1 is on a distinguished road
Hello. May be the thing is of boundary condition. In the picture one can see thin red lines along the sides of the cylinder.
This means that there is no thermal conduction between solid and fluid. Please double check. In case of the correct regime there must be the smooth
temperature transition.
Roxana_Laspiur likes this.
Roman1 is offline   Reply With Quote
Old   March 17, 2022, 08:31
Roxana Laspiur
Roman
thanks for the help.
Regarding the border conditions:
T: On the sidewall I imposed a fixed T, it seemed the right thing to do.
U: on all walls noSlip
alphat, nut, k and epsilon: I didn't modify them, is that my mistake?
alphat:
internalField   uniform 0;
boundaryField
    wallTop
        type            alphatJayatillekeWallFunction;
        Prt             0.85;
        value           uniform 0;
    wallDown
        Prt             0.85;
        value           uniform 0;
    sides
        Prt             0.85;
        value           uniform 0;
    defaultFaces
        type            empty;
k:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.1;
boundaryField
    wallTop
        type            kqRWallFunction;
        value           uniform 0.1;
    wallDown
        value           uniform 0.1;
    sides
        value           uniform 0.1;
    defaultFaces
        type            empty;
nut:
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    wallTop
        type            nutkWallFunction;
        value           uniform 0;
    wallDown
        value           uniform 0;
    sides
        value           uniform 0;
    defaultFaces
        type            empty;
epsilon:
internalField   uniform 0.01;
boundaryField
    wallTop
        type            epsilonWallFunction;
        value           uniform 0.01;
    wallDown
        value           uniform 0.01;
    sides
        value           uniform 0.01;
    defaultFaces
        type            empty;
Old   March 17, 2022, 09:04
Roman
Mostly I use the solver fireFoam but environment dynamics is similar. Important BC is pressure, try different BC beginning from the simpliest ones (fixedFluxPressure for ex, but it changes from the solver to solver). Try running without wall functions. This permits you to start the process as it is. After that you can make computing more sharp with adding wall functions. Try U: slip, too.
Old   March 17, 2022, 09:24
Roman
Useful BC for T is wallHeatTransfer
Old   March 17, 2022, 10:12
Roxana Laspiur
Roman1
Changues the BC of T
sides
        type            fixedValue;
        value           uniform 296;
for new BC of T
sides
        type               wallHeatTransfer;
        Tinf                uniform 296;
        alphaWall      uniform 5.53e-07;
When running I get the following error
--> FOAM FATAL ERROR: (openfoam-2012)
    request for compressibleTurbulenceModel turbulenceProperties from objectRegistry region0 failed
    available objects of type compressibleTurbulenceModel are
0()
    From const Type& Foam::objectRegistry::lookupObject(const Foam::word&, bool) const [with Type = Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> >]
    in file /home/usuario/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 463.
Old   March 17, 2022, 10:36
Roman
Tinf uniform 500;
alphaWall uniform 1;
I could try running your case on OpenFoam 7 or 9, but it can take 2-3 days. Generally, the fixing is to run with different combinations of the parameters.
Old   March 17, 2022, 10:50
Roman
adjustTimeStep no; Try yes
Old   March 17, 2022, 11:59
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I run a simlar case, for me a combination of natural convection and external flow. This arises much more strange "effects". I ended with the schemes:
ddtSchemes {  default Euler;}
gradSchemes { default Gauss linear; }
divSchemes {
	//// tsable and accurate
	div(U)		Gauss  linear upwind default;
	div(k)		Gauss  linear upwind default;
	div(omega)		Gauss  linear upwind default;
    div(phi,U)      Gauss linear upwind grad(U);
	div(phi,omega) Gauss linear upwind default;
	div(phi,k) Gauss linear upwind default;
snGradSchemes {
    default         limited 1;  // phi=1: 1=accurate
laplacianSchemes {
    default         Gauss linear limited  1; // phi=1: accurate
I run RAS k-w simulation:
simulationType  RAS;
RAS {
    RASModel        kOmega;
    turbulence      on;
    printCoeffs     on;
I was not very happy with LES experiments.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 18, 2022, 04:15
Roman
buoyantBoussinesqPimpleFoam: Transient solver for buoyant, turbulent flow of incompressible fluids
Is it correct using incompressible solver for natural convection? May be use another one?
Old   March 18, 2022, 04:26
piu58's Avatar
Uwe Pilz
Yes, I used buoyantBoussinesqPimpleFoam for free convection.
Uwe Pilz
Old   March 18, 2022, 07:55
Roxana Laspiur
Yes, I read that it is the right solver.
I still can't solve my problem.
Thanks for your suggestions
Old   March 18, 2022, 11:52
piu58's Avatar
Uwe Pilz
May be your downstream area is too small. The BC at the exit acts a a large distance.
Uwe Pilz
Old   March 18, 2022, 15:53
Roman
This is the OF case with your geometry (link). The case made on the base of the tutorial of OpenFoam ver. 9. All seems work OK.
https://transfiles.ru/svtdo
Old   March 18, 2022, 16:26
piu58's Avatar
Uwe Pilz
We have the situation here, that the case works as intended by the tutorial. But the result does not fulfil the theory.
I worked with that solver (buoyantBoussinesqPimpleFoam) too and found it has problems with free stream simulation. In my case I tried coupling buoyant with additional forced streaming. I was not succesfu with that coupling and had to separate the effects.
I recommend:
1) analyse the buoyant stream. The thickness of boundary layer should increase with the sqare root of the length. And the total heat transfer should be in the near where the Nußelt number calculates it. If taht is the case, all is ok with your boundary conditions.
2) simulate the stream in the upper part of the cylinder spearately. The last upper part of the cylinder soes no change the boundary stream much. You may identify the velocity in the region of 2/3 to 3/4 of the total height of the cylinder. Take that and set it as boundary condition for another case. Simulate this one without buoyancy, and with an ordninary solver like pimpleFoam.
3) If that wokrs and gives the expected result you may try to combine both effects, buoyancy and free stream in one simulation. As said, I was not lucky with that. You should experiment with solvers especially for U and p. If you change anything look first, if the buoyancy effect is still correct (square root and Nußelt condition). Look what works better and what does not.
I am very intersted to hear if you come closer to a one step simulation.
Uwe Pilz
cylinder, natural convection, water
Natural convection from heated rotating cylinder nived FLUENT 0 November 28, 2018 04:30
calculation of mass flow rate from the inner part of a vertical cylinder in natural manoj kumar dash FLUENT 5 August 24, 2018 11:57
Calculation of heat transfer coefficient of natural convection in 2D vertical plate mit326 OpenFOAM 2 August 6, 2018 20:04
natural convection from vertical plate ghassan77 FLUENT 0 January 3, 2011 02:31
natural convection from vertical plate ghassan77 FLUENT 0 January 2, 2011 03:59
