February 21, 2022, 11:43 |
Visualisation of velocityFilmShell results
Rep Power: 14 |
I ran the inclinedPlaneFilm tutorial in the new v2112 release, and then tried to visualise the results .. eg the film thickness. However, when I fire up paraview, all I can see are the U and p fields, i.e. the volume fields.
So, how do I visualise the faMesh fields, eg hf_film etc.? Presumably I need to do some additional conversion/pp'ing ... I cannot see any documentation about the faModels, other than the news release in: https://www.openfoam.com/news/main-n...er-and-physics. Any hints would be appreciated - thanks. |
February 21, 2022, 13:14 |
Rep Power: 14 |
Okay - I figured it out eventually. One way, at least is to run foamToVTK to convert the data, and then load this into paraview. The thing that tripped me up was that you need to use a -finite-area flag to force it to output the film data files, else it will just ignore them.
PS - apologies for posting this in the wrong channel - it should really be in the PostProcessing channel, but I ca't move it now. |
February 21, 2022, 14:13 |
#3 | |
Mark Olesen
Rep Power: 40 |
If you think so, drop it into a GitLab issue for tracking. Thanks |
February 21, 2022, 14:37 |
Rep Power: 14 |
Yes - I like your idea Mark. Surely the number of cases where you'd run an area model but then not be interested in postprocessing the results must be small. I'll drop it as a suggestion. Thanks.
Time sensitivity analysis - results variation | qntldoql | FLUENT | 1 | January 25, 2022 00:07 |
My results become inconsistent when using PIMPLE (nOuterCorrectors>1) instead of PISO | FloB | OpenFOAM Running, Solving & CFD | 5 | May 17, 2021 06:17 |
Validating the results of numerical modeling compared to the results of another model | ENG.AHMAD | FLUENT | 0 | June 22, 2020 16:49 |
bad heat transfer results with low y+ | me45 | OpenFOAM Running, Solving & CFD | 0 | April 29, 2020 11:56 |
Error Interpolating Results onto New Mesh | nammeh | CFX | 1 | March 26, 2019 12:08 |
