compressibleInterFoam. Problems defining liquid properties in OF8 and 9 |
February 16, 2022, 19:02 |
cbarring
Rep Power: 12 |
Hello.
I am trying to model a water-like liquid as one of the phases in compressibleInterFoam. The equation of state for this liquid would be altered due to impurities. The adiabaticPerfectFluid model would do the job. I put the adiabaticPerfectFluid model code in the thermophysicalProperties.water file. Under OF7, everything works. When I do exactly the same thing in OF8 and 9 I get: _____________________________________________ --> FOAM FATAL ERROR:------------------------------------------------------------------------ It is possible that my implementation adiabaticPerfectFluid is wrong. So I tried using the water properties from Dr. Holzmann's Blog (https://holzmann-cfd.com/community/b...operties-water). Putting this code in thermophysicalProperties.water worked in OF7 but not in OF8. The OF8 error message was: _____________________________________________ --> FOAM FATAL ERROR:------------------------------------------------------------------------ I suspect that the problem is that the OF8 and 9 versions of compressibleInterFoam require that the mixture in the domain must include a liquid and a gas. This makes sense for VOF to work. However, the choices available for "liquid" are limited to the following fluids (using the Banana Method): Ar, C10H22, .... , CH4N2O, H2O, IC8H18, .... , nC3H8O. So, to force a new equation of state onto water, I think that I need to customize the H2O file (/opt/openfoam8/src/thermophysicalModels/thermophysicalProperties/liquidProperties/H2O). I would not customize the H2O files that reside in the opt directory. I would customize a copy of this file (on in my home directory) and recompile etc. But this would be a significant effort. Or, I could just stick with OF7. Am I missing something here? Does anybody have any ideas on what I can do to easily get OF8 or 9 to work in this situation? Regards Last edited by cbarring; March 8, 2022 at 13:48. Reason: Update with new information. |
March 8, 2022, 14:11 |
cbarring
Rep Power: 12 |
Hi. This is an update to this post.
After a lot of trial and error, I found that these fatal errors are result of the following code in the thermophysicalProperties file with relates to the surface tension: sigma { type liquidProperties; phase water; } The fatal error does not occur if I replace the above code with: sigma 0.07; The modified thermophysicalProperties file is then exactly the same as the corresponding file for the depthCharge3D tutorial. So, I think that if one wants to use the liquid model in compressibleInterFoam simulations, one should use: sigma { type liquidProperties; phase water; } For other equations of state, one should use "sigma 0.07; // water". If the fluid is not water, a different value of sigma would be required. Regards |
compressibleinterfoam, fatal error, liquid properties |
