Two drops coalescing on substrate not conserving volume |
February 4, 2022, 15:19 |
Josh McCraney
Rep Power: 9 |
Hi All
Can you help with the following issue? Version: OpenFOAM 6 on Ubuntu 18.04 interFoam Simulation: two water drops on a substrate coalescing Issue: the drops are falling right through the substrate (-z direction). What am I missing? My blockMesh is here Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.01; // cm --> m xmin -4; xmax 5; ymin -3; ymax 3; zmin 0; zmax 3.5; xcells 180; ycells 120; zcells 70; vertices ( ($xmin $ymin $zmin) ($xmax $ymin $zmin) ($xmax $ymax $zmin) ($xmin $ymax $zmin) ($xmin $ymin $zmax) ($xmax $ymin $zmax) ($xmax $ymax $zmax) ($xmin $ymax $zmax) ); blocks ( hex (0 1 2 3 4 5 6 7) ($xcells $ycells $zcells) simpleGrading (1 1 1) ); edges ( ); boundary ( base { type wall; faces ( (1 5 4 0) ); } openBoundaries { type patch; faces ( (0 4 7 3) (3 7 6 2) (2 6 5 1) (4 5 6 7) (0 3 2 1) ); } ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { base { type constantAlphaContactAngle; theta0 106; limit gradient; value uniform 0; } openBoundaries { type inletOutlet; inletValue uniform 0; value uniform 0; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { base { type fixedFluxPressure; value uniform 0; } openBoundaries { type totalPressure; p0 uniform 0; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { base { type noSlip; } openBoundaries { type pressureInletOutletVelocity; value uniform (0 0 0); } } // ************************************************************************* // Last edited by joshmccraney; February 4, 2022 at 16:30. |
February 4, 2022, 16:45 |
Josh McCraney
Rep Power: 9 |
Nevermind I'm an idiot. Was setting the wrong plane as the wall in blockMeshDict. Please ignore
January 23, 2024, 11:30 |
Késsia Tayná Silva
Rep Power: 2 |
Hello joshmckraney! Even though this post is from long ago, would you please help me on how to simulate two droplets using OpenFOAM? Currently I'm able to simulate one droplet with setFields and setAlphaField, but not two. Thank you beforehand!
January 23, 2024, 12:15 |
Josh McCraney
Rep Power: 9 |
What does you setFields file look like? Can you post it here? All you should have to do is copy the block of code you use for the first drop for the second (change drop center and radius if you want, of course)
January 23, 2024, 14:41 |
#5 | |
Késsia Tayná Silva
Rep Power: 2 |
setFieldsDict: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: plus | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue alpha.phase1 0 ); regions ( // Droplet 1 cylinderToCell { p1 (0.5 0.5 -1); p2 (0.5 0.5 1); radius 0.1; fieldValues ( volScalarFieldValue alpha.phase1 1 ); } // Droplet 2 cylinderToCell { p1 (1.5 0.5 -1); p2 (1.5 0.5 1); radius 0.1; fieldValues ( volScalarFieldValue alpha.phase1 1 ); } ); // ************************************************** *********************** // setAlphaFieldDict: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: plus | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // field alpha.phase1; type cylinder; radius 0.1; direction (0 0 1); origin (0.5 0.5 0); field alpha.phase1; type cylinder; radius 0.1; direction (0 0 1); origin (1.5 0.5 0); // ************************************************** *********************** // |
January 23, 2024, 15:15 |
#6 | |
Josh McCraney
Rep Power: 9 |
January 23, 2024, 16:56 |
#7 | |
Késsia Tayná Silva
Rep Power: 2 |
I'll try that and come back to report. Thank you! |
March 12, 2024, 16:36 |
Késsia Tayná Silva
Rep Power: 2 |
Hello! I have solved my issue, so I want to put it here in case someone else ever find this problem. Running the command twice didn't work: when I ran the second time, the first droplet would be erased, as if it was the first time the command was ran. Ultimately, I stopped using "setAlphaField" and it works just fine using only the "setFields" command. I am not sure why it didn't work before, and I'm not sure why it is working now, but it is! Thank you
March 12, 2024, 18:17 |
#9 | |
Josh McCraney
Rep Power: 9 |
interfoam, volume leaving |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 19:28 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[GAMBIT] Meshing T-pipe | maxpoint | ANSYS Meshing & Geometry | 19 | November 25, 2016 02:33 |
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel | Mehrez | OpenFOAM Running, Solving & CFD | 10 | May 18, 2016 12:44 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
