adjointShapeOptimizationFoam
Like Tree1Likes
  • 1 Post By jvinuales
Old   February 3, 2022, 11:56
Default adjointShapeOptimizationFoam
Javier Vinuales
jvinuales is on a distinguished road
Hello everyone!
I am using OpenFOAM 2112, trying to assess the applicability of the adjointShapeOptimizationFoam solver for optimizing internal flows.
Is it possible to define "non-design" regions? i.e. regions where alpha must be 0.
Also, is it possible to model porous regions (apart from the implemented alpha) to model other resistances? I am guessing this will require developing a custom solver?
Thanks!
Fouch likes this.
jvinuales is offline   Reply With Quote
Old   February 7, 2022, 04:31
Javier Vinuales
regarding making "non-design" zones, I can see there is a template function "zeroCells", defined in adjointShapeOptimizationFoam.C to make variables zero.
void zeroCells
    GeometricField<Type, fvPatchField, volMesh>& vf,
    const labelList& cells
    forAll(cells, i)
        vf[cells[i]] = Zero;
This function is used in the SIMPLE loop to make the inlet cells zero alpha:
zeroCells(alpha, inletCells);
I guess this function could also be used to make "non-design areas"? anyone has tried?
