Solids4Foam:Solution crashes after changing fluid and material properties |
January 20, 2022, 13:30 |
Please select...
Dear all CFD community,
I recently started working on a project related to FSI of flexible wings. I am using turekHron fsi case from solids4foam. Since for flexible wing, atmospheric conditions are needed. Thus, I changed the boundary conditions in U directory to freestream (inlet,top,bottom patches) at 1.5 ms-1,the simulation runs perfectly(considering default fluid and solid-material properties). But as soon as change the fluid properties to air (rho-1.23, nu 1.47e-5) and solid material properties of polyethylene foam (rho 32.9, poisson ratio 0.2, E-0.849e+5) keeping freestream conditions the solution crashes after 2 seconds, showing run time error. I would be glad if you all can tell me is there anything else I need to consider to look at changing along with these porperties that leads to smooth. log file : https://drive.google.com/file/d/1wiC...ew?usp=sharing |
February 11, 2022, 10:55 |
Philip Cardiff
Rep Power: 34 |
Hi Daniel,
One thing to note is that in the HronTurek example cases in solids4foam, the FSI coupling is enabled at 2 seconds; this is done to allow the flow to develop first before enabling the coupling. If you are using the same settings then the FSI coupling is obviously unstable and blows up. If that is the case, then try make the problem easier and find what is breaking it and how to stop it breaking. e.g. try more slowly reducing the solid stiffness and density and changing the fluid properties (do one at a time), and experiment with other FSI coupling settings, egg, try Aitken's coupling. |
April 11, 2022, 07:46 |
#3 | |
efendi
Rep Power: 5 |
I want to ask a question about solids4Foam. Can this solver dissolve air and water together such as interFoam? |
April 11, 2022, 08:02 |
#4 | |
Philip Cardiff
Rep Power: 34 |
April 11, 2022, 08:04 |
#5 | |
efendi
Rep Power: 5 |
November 11, 2022, 03:22 |
#6 | |
efendi
Rep Power: 5 |
I want to study elastic material behavior for two-phase flow with solids4Foam. I want to use variableHeightFlowRateVelocity in inlet but I get an error for foamExtend 4.1 (trying to construct an genericFvPatchField on patch inlet of field rho). I tried to continue with the interElasticBeam tutorial but I am getting an error. For OpenFOAM 7, I get the error that the version is not suitable. Can you help with this? In short, I want to do something like the weirOverflow tutorial in OpenFoam 7. |
November 11, 2022, 06:01 |
#7 | |
Philip Cardiff
Rep Power: 34 |
November 11, 2022, 08:40 |
#8 | |
efendi
Rep Power: 5 |
November 17, 2022, 02:11 |
#9 | |
efendi
Rep Power: 5 |
I compiled solids4Foam with of9 as your suggestion but now ı see this message "not implemented for this version of OpenFOAM" |
November 18, 2022, 06:38 |
#10 |
Philip Cardiff
Rep Power: 34 |
November 18, 2022, 06:54 |
#11 |
efendi
Rep Power: 5 |
December 2, 2022, 14:44 |
#12 | |
Philip Cardiff
Rep Power: 34 |
I did the following:
If you want to make the weir deformable then start with the flexibleDamBreak tutorial and modify the solid and fluid meshes, solid and fluid boundary conditions, and other settings (e.g. controlDict). |
foam extend 4.0, fsi 2-way, solids4foam, turek and hron |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
