actuationDiskSource for rotor disc
Like Tree2Likes
  • 1 Post By JulioPieri
  • 1 Post By ufocfd
Old   January 13, 2022, 07:30
Default actuationDiskSource for rotor disc
Giles Richardson
ufocfd is on a distinguished road
Has anyone found a successful implementation of the actuationDiskSource method in simpleFoam (for a helicopter rotor disc type calculation) ?
I am investigating 3 methods which apply a source term on the prescribed rotor disc region (cell zone), namely:
1. mean velocity source
2. actuation disc source
3. rotor disk source
The problem I have with actuation disc source is that the prescribed values for CT and CP (thrust and power coeffs) are somewhat unstable. Using values such as 0.5 & 0.5 does nothing much, whereas larger values CP=1.0 CT=0.1 and the solution becomes unstable. It also seems sensitive to the location of upstreamPoint(x y z).
I wonder if this method is at all suitable for helicopter (or fan) rotor disc and maybe its supposed to be used only for wind turbine type calculations...?
This is what I have so far in fvOptions:
disk2
type actuationDiskSource;
// variant Froude;
// variant variableScaling;
active on;
actuationDiskSourceCoeffs
selectionMode cellZone;
cellZone rotordisc;
fieldNames (U);
diskArea 0.4;
diskDir (0 1 0);
Ct 0.5;
Cp 0.5;
upstreamPoint (0 0.5 0);
Regards Giles.
ufocfd is offline   Reply With Quote
Old   January 14, 2022, 14:47
Julio Pieri
JulioPieri is on a distinguished road
I haven't used, but from the equation, as Ct gets larger, the Thrust increases a lot.
Have you tried using other force method? Have you tried increasing Cp and Ct slowly, while letting the solution get stable at each change?
Maybe you are abruptly increasing the parameters, causing it to diverge. Try running with 0.5/0.5 for a while, then increave to, say 0.6/0.4, run for a while, etc.
ufocfd likes this.
JulioPieri is offline   Reply With Quote
Old   January 14, 2022, 15:30
Giles Richardson
good suggestions - thanks Julio.
I will repost if/when it works ok.
JulioPieri likes this.
actuationdisksource, fvoptions, helicopter, rotor disc, simplefoam
actuationDiskSource in simpleFoam hoemmaria OpenFOAM Running, Solving & CFD 38 October 29, 2023 16:10
actuationDiskSource which calculates Cp TomWaits OpenFOAM Running, Solving & CFD 5 September 20, 2023 10:16
Basic use of actuationDiskSource AlezXander OpenFOAM Pre-Processing 3 March 15, 2021 11:13
why do we need Cp for actuationDiskSource? TomWaits OpenFOAM Pre-Processing 0 July 16, 2020 13:32
actuationDiskSource ahab OpenFOAM Running, Solving & CFD 1 February 20, 2018 13:39
