water injection time adjusting
Like Tree1Likes
  • 1 Post By wjchoi
Old   January 13, 2022, 02:44
Default water injection time adjusting
wjchoi is on a distinguished road
Hello i am beginner of openfoam
when i run the example related water injection from inlet, i wonder that wether the injection of water can stop or not. clearly, i think that there may be an option to stop the water injection by time in openfoam. for example, if i set the time of water injection to 0s ~50s, the time of water injection is only 0s ~50s. in other words, after 50s from starting simulation, water injection will stop.
but, i did't find the option to set the water injection time.
i only found the option to set the "bubble" injection time in water (constant/fvOption/points --> timeStart, duration __ i wrote the code related this in the below)
[code]
options
massSource
type semiImplicitSource;
timeStart 0.1;
duration 5;
selectionMode points;
points
(0.075 0.2 0.05)
volumeMode absolute;
and i found that if i want to inject the water from inlet to some domain, i can adjust the boundary condition of alpha.water file and U file in "0" folder. but, when i saw these files, there is not an option to adjust the water injection time unlike bubble injection in fvOption as i mentioned above. so if the time of simulation is enough long, the water always full in the domain..
(i wrote the code related this in the below )
[code]
boundaryField
inlet
type flowRateInletVelocity;
volumetricFlowRate constant 5;
~~~ (there is no option like timeStart, duration)
wjchoi is offline   Reply With Quote
Old   January 13, 2022, 04:39
Yann
Yann will become famous soon enoughYann will become famous soon enough
You should be able to define the flowrate in a table function of time.
For instance, in the example below, the flowrate will ramp from 0 to 5m3/s during the first 10s of simulation, then maintain a constant flowrate of 5m3/s from 10 to 50s and then decrease the flowrate up to 0 between 50 and 60s.
I did not test this, you might have to adjust the syntax.
inlet
    volumetricFlowRate table ((0 0)(10 5)(50 5)(60 0));
Cheers,
Yann
Yann is offline   Reply With Quote
Old   January 13, 2022, 08:44
Originally Posted by Yann View Post
inlet
Cheers,
Yann
oh
the code you wrote worked well as i intended,, thank you very much!
Yann likes this.
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores puneet336 OpenFOAM Running, Solving & CFD 11 April 7, 2019 01:58
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
