Q: How to access turbulent production term G from TKE in scalarCodedSource
Like Tree2Likes
  • 1 Post By Kbshariff
  • 1 Post By Tobermory
Old   January 11, 2022, 06:51
Default Q: How to access turbulent production term G from TKE in scalarCodedSource
Kabir Shariff
Kbshariff is on a distinguished road
I would like to implement a source term into k-epsilon model in a given location using the scalar coded source in fvOptions.
I implemented the k source and it works fine, but the epsilon source term need the production term of the TKE, G. How can I get this term into the equation?
The source term is given in the figure attached herewith.
Thank you.
Kbshariff is offline   Reply With Quote
Old   January 11, 2022, 09:47
Julio Pieri
JulioPieri is on a distinguished road
Is this field natively available by the solver?
You can check it by running a "dummy" functionObject that will give you an error and print all available fields:
FIELDSAVAILABLE
        type                 writeObjects;
        libs            ("libfieldFunctionObjects.so");
        executeControl  writeTime;
        writeControl        writeTime;
        objects
        ("HIMYFRIEND");
Check if you can see the field you're looking for printed.
If you can, you may access it with something like
mesh().lookupObject<volScalarField>("FIELD");
changing Scalar to Vector depending on the type.
If you can't, then you might need to re-write it from the other available fields
JulioPieri is offline   Reply With Quote
Old   January 11, 2022, 10:34
Kabir Shariff
FIELDSAVAILABLE
        type                 writeObjects;
        objects
        ("HIMYFRIEND");
Hello, thanks for the reply, I checked the term is not listed in the available field list.
the TKE production term G is defined in the KEps model as;
It is defined in the .C fine as
    const volScalarField::Internal G(this->GName(), nut()*GbyNu);
    tgradU.clear();
here
    // Turbulent kinetic energy equation
    tmp<fvScalarMatrix> kEqn
        fvm::ddt(alpha, rho, k_)
      + fvm::div(alphaRhoPhi, k_)
      - fvm::laplacian(alpha*rho*DkEff(), k_)
        alpha()*rho()*G
      - fvm::SuSp((2.0/3.0)*alpha()*rho()*divU, k_)
      - fvm::Sp(alpha()*rho()*epsilon_()/k_(), k_)
      + kSource()
      + fvOptions(alpha, rho, k_)
How can I get the production term for the solver?
Clément_G likes this.
Old   January 11, 2022, 10:52
Julio Pieri
Hmm so this is harder. I'd try recreating this expression:
tgradU().v() && dev(twoSymm(tgradU().v())) * nut()
but I'm not sure how to get each of the terms, though they might be accessible.
As alternatives you could edit the code to make this variable accessible, or use swak4Foam that usually have access to more fields. Not sure how to use it for fvOptions though.
Old   January 11, 2022, 15:57
Tobermory will become famous soon enough
You are right Julio, but most of those terms (tgradU(), twoSymm(tgradU().v())) will not be stored on the registry, so you'll have to recreate them from the velocity field. Just follow the coding in the kEpsilon model, and you should be fine.
JulioPieri likes this.
Tobermory is offline   Reply With Quote
fvoptions, kepsilon, scalarcodedsource, source term
scalarCodedSource how to access to field instance samiahmed OpenFOAM 1 June 30, 2019 21:51
How to access nu and nut values for a Turbulent Solver suman91 OpenFOAM Programming & Development 9 December 19, 2018 07:17
laplacian term in turbulent model chai OpenFOAM Running, Solving & CFD 4 March 8, 2012 10:28
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Numerical method for the k-epsilon production term carlslack Main CFD Forum 0 January 23, 2003 17:13
