P1 Model with no participating media - Heat fluxes not matching |
Rep Power: 5 ![]() |
Hi all! Thanks to all the people working on OpenFoam and helping the community. I am new on this forum but I have been browsing the topics for quite some time now, and all the answers I find are always appreciated, so thanks for your time.
I have an issue that I can't seem to solve. For a project, I am trying to use a P1 radiation model with buoyantSimpleFoam, but with no participating media (air inside a closed cylinder). I am aware that viewFactors or fvDom might be more suited and more accurate, but I want to first try this model. The geometry is a simple cylinder, and one of the extremities generates heat via an externalWallHeatFluxTemperature BC. The cylinder and the other extremities are also externalWallHeatFluxTemperature BCs, with ambient temperatures. My issue comes from setting the emissivity and absorptivity in radiationProperties to 0 (or using "none" as the model for AbsorptionEmission"). The heat fluxes (monitored with wallheatflux) no longer match, although with emissivity/absorptivity = 1, they eventually do. I have reproduced the examples, so all the files (G, boudaryRadiationProperties...) are similar to what we can find in the examples. Any clue on what is responsible ? Let me know if more details are needed, and thanks for your help! |
With absorptivity=1 the sum of the heat fluxes on all the patches equals 0, but with absorptivity=0 there is a significant difference between the heat flux entering the domain and the ones leaving (sum not 0).
I use these values to try and see if my settings are relevant, maybe I am mistaken. |
Derek Mitchell
Rep Power: 13 ![]() |
P1 is well known to be inaccurate with zero participating media [1]
I have validated the Openfoam P1 model and it appears to be for my geometry to be 1.9 times overestimating radiation with zero participating media. I found for my work it was possible to adjust the emissivity to correct for the error with a "real" 0.95 emissivity being replaced with a 0.6 emissivity. This might not suffice for your application. Sazhin, S. S., Sazhina, E. M., Faltsi-Saravelou, O., & Wild, P. (1996). The p-1 model for thermal radiation transfer: Advantages and limitations. Fuel, 75(3), 289–294. https://doi.org/10.1016/0016-2361(95)00269-3
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET |
Thanks for sharing your results, it clearly confirms what I found when I investigated the issue. I ended up using the fvDOM model and the results are quite close to the experimental data.
My only remaining issue is that I can't seem to make cyclic or symmetry boundary conditions work with the fvDOM model, whereas the P1 model seemed easier to set up with such conditions. I am still looking but I jut don't have the time right now ![]() Anyways, I appreciate the feedback, cheers! |
#6 | |
Derek Mitchell
They dont work at all with cyclic or symmetry boundary conditions and FVDOM is expensive in computation
#7 | |
Oh well, I guess I won't have to think about it again, thanks for clarifying once and for all. Let's hope they manage to implement these features in the future updates, the DO model in Fluent works with symmetry and cyclic boundaries. |
#8 | |
Berk
Rep Power: 8 ![]() |
Hello Derek, could you please tell me where you actually set the "emissivity" in OF-case? In the boundary conditions as a surface emissivity (in 0-Folder) or in the constant/radiationProperties? The reason I ask is that there is also an "emissivity" in constant/radiationProperties, but it has the unit 1/m, which is a bit confusing. Thank you very much! |
#9 | |
Derek Mitchell
constant/radiationProperties it has those dimensions so it can work for Fluids as well. For solids very confusing
#10 | |
Berk
thank you very much for your quick reply! So, for a case with multiple regions (one solid-region and one fluid-region), can I directly consider the emissivity of my solid in constant/solid/radiationProperties to be dimensionless? I just need to get the emissivity of my solid (e.g. aluminum) and then set this dimensionless value in constant/solid/radiationProperties as emissivity? So does the unit 1/m refer only to the length dependence of the emissivity of fluids? Last edited by altinel; July 31, 2022 at 10:04. Reason: typo |
#11 | |
Derek Mitchell
#12 | |
Derek Mitchell
#13 |
Berk
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Cooling- Heat transfer model | Markat | FLUENT | 9 | February 9, 2013 00:22 |
