How to see total elapsed time of simulation?
Like Tree2Likes
  • 1 Post By zweihuehner
  • 1 Post By courant_numero_uno
Old   December 8, 2021, 16:27
Default How to see total elapsed time of simulation?
Josh McCraney
joshmccraney is on a distinguished road
Hello all
Is there a way for me to see how long it's taken to run sims? After executing the command
mpirun -np 16 interFoam -parallel
the time pops up in the terminal. But if I close the terminal I'll lose the total runtime. Is there a way to see this, like in a printed file?
joshmccraney is offline   Reply With Quote
Old   December 8, 2021, 20:27
Faro Schäfer
zweihuehner is on a distinguished road
You could redirect the output to a file like so:
Linux:
mpirun -np 16 interFoam -parallel > log.txt &
Windows:
START /B mpirun -np 16 interFoam -parallel > log.txt
Explanation:
  • > log.txt redirects to a text file
  • [...] & (Linux) and START /B [...] (Windows) run the program in the background
Hope this helps
joshmccraney likes this.
zweihuehner is offline   Reply With Quote
Old   December 30, 2021, 22:12
Josh McCraney
Thanks so much for the reply! Quick question: if a run this command, then exit the simulation and then resume, will the time be total elapsed or just the time since I re-executed the simulation
Old   January 5, 2022, 13:26
courant_numero_uno is on a distinguished road
The time in the logs will always be for each separate call of the solver. The symbol > will overwrite the log file after each call. If you want to append to the log file instead, use >>. Alternatively, you can just change the name of the log each run (e.g., command > log1, command > log2).
courant_numero_uno is offline   Reply With Quote
Epyc 7551 vs 6850K; Ansys Mechanical Bench Duke711 Hardware 24 March 26, 2020 11:16
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
Error in run Batch file saba1366 CFX 4 February 10, 2013 02:15
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
