simpleFoam kOmegaSST k, w and nut initial and boundary values
Like Tree1Likes
  • 1 Post By Ryuzaki
Old   December 6, 2021, 02:22
Default simpleFoam kOmegaSST k, w and nut initial and boundary values
Ezel Bayraktar
Ezel Bayraktar is on a distinguished road
Hello Everyone,
I am trying to simulate flow over an airfoil using simpleFoam and turbulence model kOmegaSST. I have taken k, w and nut values from http://ichrome.com/blogs/archives/342 and http://www.wolfdynamics.com/tools.html?id=110. But after several iterations, soltion diverges. After changing these values many times, I have obtained a stable solution. My question is; how could we select values of these turbulence parameters.
with all respect...
Ezel Bayraktar
Ezel Bayraktar is offline   Reply With Quote
Old   December 6, 2021, 14:28
Ali Can
Ryuzaki is on a distinguished road
Hi Ezel, if you are sure that the turbulence coefficients you use are correct, you can try to reduce the relaxation factors to get stable results.
Eyşan Tezcan Atay
saidc. likes this.
Ryuzaki is offline   Reply With Quote
Old   December 6, 2021, 14:32
Eren
ErenC is on a distinguished road
You need to share your log so people can see/understand whats happening. A simulation can diverge from hundreds of reasons.
ErenC is offline   Reply With Quote
Old   December 30, 2021, 08:08
Default İntikam
Ezel Bayraktar
Eyşan Tezcan Atay
Niye lan niye...
komega sst model, komegacoeffs, simplefoam convergence
simpleFoam kOmegaSST k, w and nut initial and boundary values Ezel Bayraktar OpenFOAM Bugs 0 December 3, 2021 09:27
alphat Wien3 OpenFOAM Running, Solving & CFD 22 August 15, 2019 11:00
Airfoil with simpleFoam and kOmegaSST: high drag values? Tsiolkovsky OpenFOAM Running, Solving & CFD 6 November 21, 2018 06:56
Initial values and boundary condition for LES simulation of a box SaddamH OpenFOAM Running, Solving & CFD 1 July 31, 2018 03:21
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
