Entry 'UFinal' not found in dictionary
Like Tree1Likes
  • 1 Post By tomf
Old   November 19, 2021, 07:05
Default Entry 'UFinal' not found in dictionary
Jacob H
Jacobhh is on a distinguished road
Hi, OpenFoam newbie here.
Im trying to implement a pimpleFoam solver for the OpenFoam v2106 simpleFoam tutorialcase for a backwards facing step.
No matter what i do the same error seems to arrise. What am i doing wrong here?
fvSolution file;
|  \\    /   O peration     | Version:  v2106                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
    p
        solver           GAMG;
        smoother         DICGaussSeidel;
        tolerance        1e-4;
        relTol           0.001;
    pFinal
        $p;
        relTol          0;
    "(U|k|epsilon|omega)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-6;
        relTol          0.1;
    "(U|k|epsilon|omega)Final"
        $U;
        tolerance       1e-06;
        relTol          0;
PIMPLE
    nNonOrthogonalCorrectors 0;
    nCorrectors          1;
    nOuterCorrectors    50;
    residualControl
        U
                tolerance  1e-5;
                relTol      0;
        p
                tolerance  1e-4;
                relTol      0;
relaxationFactors
    fields
        p      0.8;
        pFinal   1;
    equations
        "(U|k|epsilon|omega)"     0.8;
        "(U|k|epsilon|omega)Final"   1;
Error log;
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
RAS
    RASModel        kOmegaSST;
    turbulence      on;
    printCoeffs     on;
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
    decayControl    false;
    kInf            0;
    omegaInf        0;
No MRF models present
No finite volume options present
Courant Number mean: 0.00934313 max: 0.11311
turbulenceFields stressComponents: storing fields:
    turbulenceProperties:devReff
pressure pressureCoefficient:
    Operating mode: staticCoeff
    Not including hydrostatic effects
Reading set description:
    Uref
    x_by_h_m04
    x_by_h_01
    x_by_h_04
    x_by_h_06
    x_by_h_10
wallShearStress wallShearStress:
    processing all wall patches
Starting time loop
deltaT = 0.00120005
Time = 0.00120005
PIMPLE: iteration 1
--> FOAM FATAL IO ERROR: (openfoam-2106)
Entry 'UFinal' not found in dictionary ""
    From const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&, Foam::keyType::option) const
    in file db/dictionary/dictionary.C at line 537.
FOAM exiting
Best,
J
Jacobhh is offline   Reply With Quote
Old   November 23, 2021, 17:18
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi J,
My guess would be that you miss the solvers keyword:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver           GAMG;
        tolerance        1e-4;
        relTol           0.001;
    pFinal
        $p;
        relTol          0;
        tolerance       1e-6;
        relTol          0.1;
        $U;
        tolerance       1e-06;
        relTol          0;
PIMPLE
    nCorrectors          1;
    residualControl
        U
                tolerance  1e-5;
                relTol      0;
        p
                tolerance  1e-4;
                relTol      0;
relaxationFactors
    fields
        p      0.8;
        pFinal   1;
    equations
In your example the bold line is missing. Not 100% sure if that would solve it, but worth a try.
Cheers,
Tom
ayubsulong likes this.
tomf is offline   Reply With Quote
backward facing step, pimple. openfoam
error in fireFoam, when running the case wallFireSpread2D zhoubiao1088 OpenFOAM Running, Solving & CFD 9 February 1, 2018 19:45
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 06:29
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 12:37
missing vtf3.h BPatch.h papi.h linch OpenFOAM Installation 41 July 24, 2012 15:45
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
