What is spectral distribution in radiation models of openfoam? |
November 16, 2021, 09:16 |
Bushra Rasheed
Rep Power: 5 |
Hi!
I have come across spectral distribution (2 1) as an input asked from user in almost all radiation models including solar load. I don't know what does it mean in the radiation models of openfoam..Is it related to number of bands? or is it power divided by wavelength? I'm lost. Please help! Thanks |
November 16, 2021, 13:54 |
Julio Pieri
Rep Power: 9 |
I'm not an expert, but from the source code solarLoad.C:
{ qprimaryBf[patchID][localFaceI] += (qPrim & n[localFaceI]) * spectralDistribution_[bandI] * absorptivity_[patchID][bandI]()[localFaceI]; } Also, from other sources I get that it is a way to weight the flux. Lastly, from fvDOM.H: HTML Code:
spectralDistribution is the energy spectral distribution of the collimated external beam. |
November 17, 2021, 02:31 |
#3 | |
Bushra Rasheed
Rep Power: 5 |
I have found the formula for calculating spectral distribution (screenshot attached). So from the code, it looks like there are two bands ; band 1 has value of 2 W/m2.nm and band 2 has value of 1 W/m2.nm. Do you know how bands are defined in radiation? like which wavelength range corresponds to which band? Thanks |
November 17, 2021, 07:56 |
Julio Pieri
Rep Power: 9 |
As from the formula you posted, the spectral step is infinitesimal (del_lambda).
When you approximate it to a finite interval, you consider delta_lambda for you "integration" over the wavelength. So you calulate it for each interval o wavelength you want to consider. Again, I'm no expert, but you might want to discretize your band (i.e. visible light spectrum) into, say, 10 steps. So you delta_lambda would be WholeBand/10. Each of this step will contribute differently to the flux |
November 22, 2021, 03:15 |
#5 | |
Bushra Rasheed
Rep Power: 5 |
I have made some observations: When I increase spectral distribution from (2 1) to (5 2) to see it’s effect on results, qr becomes 840 W/m2. Changed it to (10 20) and got value of 1200 W/m2. Again changed it to it to (20 10) and got value of 880 W/m2. I don't know the explanation for my findings. Can you explain this weird trend? |
November 22, 2021, 09:18 |
Julio Pieri
Rep Power: 9 |
I'm not sure, but reading the solarLoad.C file, it seems it is weighting over bands
spectralDistribution_ = spectralDistribution_/sum(spectralDistribution_); 1- the first number is the number os bands and the second a weight factor. 2- the array is a distribution over the band in equal steps. For instance, you could write something like (1 2 3 2 1) so 10% would be on the first 1/6th, 20% on the second, etc. Try putting more numbers in the array to check this |
November 24, 2021, 04:04 |
#7 | |
Bushra Rasheed
Rep Power: 5 |
[2] --> FOAM FATAL ERROR: (openfoam-2106) [2] Radiation bands : 5 Bands on patch : 0 is 2 I guess this means that the entries in spectral distribution are weights for each band Last edited by B_R_Khan; November 24, 2021 at 05:07. |
November 24, 2021, 08:18 |
Julio Pieri
Rep Power: 9 |
Thanks! I was expecting to be the whole spectrum actually... Because it's weird that we limit the inputs in just two scalars. I'd expect more versatility
Let's see, isn't there any other file where you specify the number of bands? Edit: try exploring the boundaryRad file. Take a look at the error: Code:
// Model number of bands label nBands = radiation.nBands(); const IOdictionary radiationDict(boundaryIO); forAll(mesh.boundary(), patchi) { const polyPatch& pp = mesh.boundaryMesh()[patchi]; if (radiationDict.isDict(pp.name())) { const dictionary& dict = radiationDict.subDict(pp.name()); radBoundaryPropertiesPtrList_[patchi].reset ( boundaryRadiationPropertiesPatch::New(dict, pp) ); if (nBands != radBoundaryPropertiesPtrList_[patchi]->nBands()) { FatalErrorInFunction << "Radiation bands : " << nBands << nl << "Bands on patch : " << patchi << " is " << radBoundaryPropertiesPtrList_[patchi]->nBands() << abort(FatalError); } } Is your mesh heavy? Send me you case file (preferebly in zip format) and I'll have a look |
November 25, 2021, 03:48 |
#9 | |
Bushra Rasheed
Rep Power: 5 |
I did not change number of entries in absopritvity and emissivity arrays in radiation boundaries before and hence got the error: Code:
panel { type opaqueReflective; // Fraction of the reflected is diffussive fd 0; // 0: all specular 1: all diffusive wallAbsorptionEmissionModel { type multiBandAbsorption; absorptivity (0.3 0.7); emissivity (0.3 0.7); }; } I will try it with 5 entries of spectral distribution & 5 absorptivity/ emissitivity entries and let you know about the results. But the question still stands that which band interval ( UV, visible etc?)will correspond to which value of spectral power. Sorry I can't send the case files right now without asking my supervisor Let me ask him and I will get back to you. I used simpleSolarCar tutorial from openfoam.com as the base files. Thanks!! Bushra |
November 25, 2021, 08:23 |
#10 |
Julio Pieri
Rep Power: 9 |
Well, that I don't know for sure. I'd expect to be just infrared, since we're interested in heat transfer, but I just read that Fluent uses a parameter to weight between visible and infrared. Try digging into the OF code, or looking at Fluent's manual! Let me know if you figure out.
November 26, 2021, 05:02 |
#11 | |
Bushra Rasheed
Rep Power: 5 |
So I changed the absorptivity and emissivity of panel in radiation boundary condition to (0.3 0.7 0.3 0.3 0.3) and spectral distribution to (2 1 3 2 1) and the simulation gave no error! The maximum irradiance on panel surface decreased from 880 w/m2 with (2 1) spectral distribution to 550 W/m2 with the current five band spectral distribution. I have skimmed through Fluent manual and yes you are right, it considers two bands for diffuse light i-e visible and infrared. If openfoam is accepting 5 bands in solar Load then maybe it is dividing the infrared, visible and UV range into 5 equal wavelength intervals with each interval having it's own flux value defined in spectral distribution. I will look more into it. Thanks! |
November 26, 2021, 07:44 |
#12 |
Yann
Rep Power: 29 |
Hi Guys,
I am far from a radiation expert, but I tried to play around the radiation models in OpenFOAM and bumped into pretty much the same questions than you do. From what I have seen in the code, I think there not any notion of wavelength anywhere because it is not relevant for the code. You can split your spectrum in N bands, give weights to each band thanks to the spectral distribution parameter, and adjust your material properties giving the emissivity and absorptivity on each band. The code doesn't need to know whether it is UV, visible or whatever, as long as it has the information to compute the proper spectral distribution and the proper wall behavior. This is up to the user to know which band he is defining, and correctly adjust the spectral distribution and wall emissivity/absorptivity to be physically correct. Does that make sense to you? Cheers, Yann |
November 29, 2021, 01:25 |
#13 | |
Bushra Rasheed
Rep Power: 5 |
radiation modelling, solar load model, solarcalculator |
Size Distribution Models - Spray Modelling | Azanulbizar | OpenFOAM Running, Solving & CFD | 18 | January 26, 2022 12:32 |
LES scale similarity and mixedSmagorinsky models for OpenFOAM v4.x or above | eddykendo | OpenFOAM | 0 | August 9, 2018 03:59 |
Radiation boundary conditions for flow through boundaries in openFoam | DustExplosion | OpenFOAM | 6 | June 27, 2018 12:49 |
Using radiation models for plasmas | chriss85 | OpenFOAM Running, Solving & CFD | 2 | February 10, 2014 12:17 |
Radiation P1 Model with Spectral Model: Multigray | A. Thellmann | CFX | 0 | October 25, 2008 13:44 |
