InterFoam for open channel: High velocities in air phase
Like Tree2Likes
  • 2 Post By David*
Old   November 8, 2021, 11:10
Default InterFoam for open channel: High velocities in air phase
Zürich
river_fish is on a distinguished road
Hi everybody,
I am trying to simulate open channel flow using InterFoam solver and RAS k-epsilon for turbulence modelling. What I know is the flowRate at the inlet and the water level at the outlet. I have tried all kinds of different BC (including splitting the inlet and outlet to air and water) but I always get problems with high velocities in the air phase, which lead to a very small time step and eventually to floating point error. I therefore assume a problem with my initial or boundary conditions:
Initial condition: constant water level at 443 m, zero velocity (0 0 0) everywhere
Inlet BC:
1. U: variableHeightFlowRateInletVelocity
2. p_rgh: zeroGradient
3. alpha_water: variableHeightFlowRate
Outlet BC:
1. U: zeroGradient
2. p_rgh: fixedValue uniform 0
3. alpha.water: zeroGradient
Besides inlet and outlet, I defined two patches, for the atmosphere and the channel bottom with the following BC:
Atmosphere:
1. U: zeroGradient
2. p_rgh: totalPressure
3. alpha.water: inletOutlet
Channel bottom:
1. U: fixedValue uniform (0 0 0)
I'm happy to provide you with more information (i.e. BC for k, epsilon and nut) and would be really grateful if I could get some advice on how to solve this problem. Thanks in advance!
river_fish is offline   Reply With Quote
Old   November 10, 2021, 02:14
David GISEN
David* is on a distinguished road
In my experience, two things are important to prevent such behavior:
  • initialize an absolutely flat water level, preferably within a small cell layer (~10-20 cm) or even at a cell boundary. For this, you need some effort in mesh generation though.
  • correct for deviation from z=0, either by using interFoam's href or by shifting the entire mesh, to have the water level in your model close (<10 m) to z=0.
Cheers, David
Drew.M and Pablo34 like this.
David* is offline   Reply With Quote
Old   November 13, 2021, 04:09
Zürich
Hi David,
Wow, that was very helpful. I did not realize I had to correct for deviation from z=0. Thanks a lot for pointing this out!
Cheers, David
boundary condition, high air velocity, interfoam
High velocities near walls in a cross junction PoSchwarz OpenFOAM Running, Solving & CFD 0 June 14, 2021 14:13
interFoam high air phase velocities indy07cz OpenFOAM Running, Solving & CFD 1 November 8, 2017 06:00
Can people model 2 phase fluid flow (air water) in 6 mm tubing? gaiatechnician Main CFD Forum 0 August 25, 2015 15:20
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
