How to control diverging value of temperature
Like Tree2Likes
  • 2 Post By Tobermory
Old   October 14, 2021, 09:52
Default How to control diverging value of temperature
L S
silviliril is on a distinguished road
I am trying to simulate subcooled flow boiling with the help of phaseChangeHeatFoam.
The geometry is made 2D representing a pipe flow situation. The case set up is attached with below.
I have been observing during subcooled flow boiling, wherever there is no liquid in contact with the heated wall and only vapor is in contact, the wall temperature keeps rising infinitely like this (see maximum T = 7598.001 K):
MULES: Solving for alpha1
Liquid phase volume fraction = 0.2654015 Min(alpha1) = 1.563196e-09 Max(alpha1) = 1
Liquid phase volume fraction = 0.2654011 Min(alpha1) = 1.563192e-09 Max(alpha1) = 1
Liquid phase volume fraction = 0.2654007 Min(alpha1) = 1.563165e-09 Max(alpha1) = 1
Liquid phase volume fraction = 0.2654003 Min(alpha1) = 1.563161e-09 Max(alpha1) = 1
DILUPBiCG: Solving for Ux, Initial residual = 0.002465843, Final residual = 4.457022e-09, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 0.0008184533, Final residual = 1.029827e-11, No Iterations 5
GAMGPCG: Solving for p_rgh, Initial residual = 0.0001695675, Final residual = 7.185041e-09, No Iterations 9
time step continuity errors : sum local = 9.484659e-06, global = 9.483099e-06, cumulative = 8.552475
GAMGPCG: Solving for p_rgh, Initial residual = 2.088834e-05, Final residual = 8.805387e-09, No Iterations 4
time step continuity errors : sum local = 9.483124e-06, global = 9.483083e-06, cumulative = 8.552485
GAMGPCG: Solving for p_rgh, Initial residual = 1.530388e-05, Final residual = 3.873035e-09, No Iterations 5
time step continuity errors : sum local = 9.483103e-06, global = 9.483038e-06, cumulative = 8.552494
solve TEqn
DILUPBiCG: Solving for T, Initial residual = 0.0003295428, Final residual = 3.655628e-12, No Iterations 4
TAve = 1569.162 Min(T) = 48.78237 Max(T) = 7598.001 <-
ExecutionTime = 14306.4 s ClockTime = 14333 s
Courant Number mean: 0.01276589 max: 0.1493844
Interface Courant Number mean: 0.002812059 max: 0.1287168
deltaT = 2.455655e-07
Time = 1.3642520479467
The non-physical temperature rise results in further rapid evaporation of liquid and slowly the entire liquid evaporated in domain which is incorrect.
How do I control the wall temperature? Is there any way to limit the temperature like some option in fvschemes or fvsolutions? Is there any way to provide minimum and maximum values limit in source code?
silviliril is offline   Reply With Quote
Old   October 14, 2021, 11:19
Tobermory will become famous soon enough
From a quick look at your case, I can see that you are applying a constant gradient (i.e. constant heat flux) boundary condition on T at the wall. This applies whether there is liquid or gas next to the wall.
Now think about the physics - is this constant heat flux realistic? The answer is no, and that is why you are ending up with excessive wall temperatures, as the code is trying to achieve your BC. The heat transfer is much less efficient when there is vapour next to the wall, and this should therefore drop your heat flux ...
So, can I suggest you have a rethink about your T boundary condition. Good luck, and come back and tell us how/when you have cracked it!
silviliril and saidc. like this.
Tobermory is offline   Reply With Quote
Old   October 14, 2021, 11:28
Default Any idea on how to write heat flux?
L S
I have been struggling a lot on how to apply the heat flux boundary condition with Scharge or Lee models as most tutorials are using constant wall temperature boundary condition.
Do you have any idea on how to effectively apply heat flux boundary condition using groovyBC?
I tried using dT/dX = q''/keff; Where keff = alpha*k_L+(1-alpha)*k_V;
k_L = Thermal conductivity of liquid and k_V = thermal conductivity of vapour.
But, this was worsening the calculation.
boiling, heat transfer, openfoam, phase change heat foam
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Closed Domain Buoyancy Flow Problem Madhatter92 CFX 6 June 20, 2016 22:05
Is wall ajacent temperature equal to conservative temperature of the wall? shenying0710 CFX 8 January 4, 2013 05:03
natural convection mehrdadeng CFX 10 February 25, 2011 06:25
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 11:55
