September 28, 2021, 12:55 |
no vortex shedding - flow over a cylinder
Gabriel
Rep Power: 5 |
Hi, im trying to simulate flow over a cylinder at Re =1.02e4 with simplefoam, komega sst, no vortex shedding appears, i used pimplefoam and its the same, no shedding, why this happens? i should be getting vortex shedding but nothing shows.
September 28, 2021, 13:01 |
Marco Müller
Rep Power: 13 |
Hi, just looking at your picture I guess your mesh is way too coarse. Also the domain is too small.
September 28, 2021, 15:34 |
Gabriel
Rep Power: 5 |
ok im going to fix that, thanks.
September 28, 2021, 21:55 |
Gabriel
Rep Power: 5 |
i made a finer mesh and got better results, but if i make a more finer mesh simplefoam gives floating point exception, im using gmsh to make the mesh
September 29, 2021, 09:53 |
Rep Power: 9 |
Check your timestep size / CFL number? CFL should normally be below 1 if you want to capture unsteady flows accurately.
September 29, 2021, 13:58 |
No Vortex shedding for diameter of 20mm in flow past cylinder | shashanktiwari619 | FLUENT | 0 | January 11, 2017 21:03 |
Flow Past a Cylinder, the Onset of Vortex Shedding | Nauseouslyquick | Main CFD Forum | 3 | October 23, 2016 16:46 |
Cylinder flow - vortex problems | RJ1331 | Main CFD Forum | 3 | December 15, 2014 19:46 |
Desperate HELP please: Vortex Shedding not showing circular cylinder | u50mb9 | FLUENT | 6 | May 1, 2012 18:23 |
Vortex shedding from a cylinder | Cylinder Case | Phoenics | 4 | February 21, 2006 08:18 |
