September 20, 2021, 07:44 |
A question about Immersed Boundary Method
mohammad
Rep Power: 12 |
Hi Everyone,
I have a question about immersed boundary method. As you know, IBM tries to solve Navier-Stokes equation using a Cartesian grid. So why we have something like the attached image for pressure field, even with non-zero values inside the rigid object? Cheers, Mohammad |
October 3, 2021, 07:59 |
Hrvoje Jasak
Rep Power: 33 |
If you want to get rid of the internal pressure values, set the deadCell value in the boundary conditions for the immersed boundary.
The way I manipulate the matix will give you something (smooth) in dead cells, which is nice. It does not influence the solution elsewhere. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
October 3, 2021, 18:51 |
#3 | |
mohammad
Rep Power: 12 |
Hi Hrvoje I am quite familiar with your approach (ghost cell) in IBM. However, I am using a different algorithm which was proposed by Patankar: A new mathematical formulation and fast algorithm for fully resolved simulation of self-propulsion This method has been implemented in CFDEM package, and more specifically, cfdemSolverIB solver. The algorithm follows the following steps: The main issue for me is the outer loop which is a piso/pimple algorithm. The algorithm works properly for Newtonian case as it assumes constant fluid viscosity even inside the particle. However, when I change it to a shear-thinning power-law flow, viscosity inside the particle should be so high, and something goes wrong with algorithm and pressure around/inside the particle: I can provide for you further information. Thank you for your time and consideration. Mohammad |
October 4, 2021, 05:46 |
Hrvoje Jasak
Rep Power: 33 |
I would be happy to look at this for you under a support contract. Please contact me via Wikki.
Hrv
October 5, 2021, 00:42 |
mohammad
Rep Power: 12 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
UDF for Automatic Solution Initialization for previous case data file | gartz89 | Fluent UDF and Scheme Programming | 6 | March 30, 2020 07:38 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
